Old 01-26-2009, 07:42 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
rant -why is my wiring soooo hard work?
<rant> my injector wiring is all wraped up in big plastic shielding and i cant get to it! i just spent 2 hours in the cold trying to get to the injectors. i even have a wiring diagram now so i was really keen to do it. it is underneath sooo many other things. fuel lines, sensors, throtle housing. i have to take all that off! the ECU end is just as bad, worse even.
its gonna be a whole weekends work! <rant/>
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 01-26-2009, 07:59 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Welcome to fuel injection,
Old 01-26-2009, 08:03 PM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Welcome to "No user serviceable parts inside." and security screws with "we know the screw's position" marks.
You just gotta have a little "stick-to-it-ive-ness" to really get something done anymore.
Old 01-26-2009, 09:35 PM   #4 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
just wait until it's warmer; it will be so much easier and the wires/insulation will be more pliable.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 01-26-2009, 09:37 PM   #5 (permalink)
If you have a garage, take a mid-distance trip (20 miles or so) and then park it in the garage... after about 30-40 mins, you should be able to work on it, and everything will be heated/much easier to work with.
I must stress that you don't remove anything which requires a gasket until the engine is cold, though. Warpage could occur.
Old 01-27-2009, 07:13 PM   #6 (permalink)
thanks for the moral support
How hard is fiberglass to work with? homeworkhome53 Aerodynamics 10 07-15-2008 04:30 PM
