Old 07-02-2013, 07:52 PM   #1 (permalink)
My C-Max - '13 Ford C-Max SEL
Leading edge air dam?
Question for you guys;
I am dropping the chin air dam on my car to match the lowest portion of my pan (2013 C-Max). I need to drop it 3 inches. The question I have for you is, would it be best to make the air dam configured in a way that the bottom edge is further forward than the top therefore creating a bit of a ramp to sweep the air upward over the nose, rather than a flat vertical surface? I am thinking to make the lower edge about 1 inch ahead of the rest of the dam. So, there would just be a modest ramp affect (I want to make sure it looks ok).
What are your thoughts?
Matt
Old 07-03-2013, 01:15 AM   #2 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
I don't think it will make a measureable differance.
That said my current airdam is angled out a little(about 1") previous one was flat, my mpg is about the same.
Old 07-03-2013, 07:36 AM   #3 (permalink)
Thanks for the input.
One other question;
I added a center and lower grille blocks. The air openings are ovals cut into the fiberglass block panels. I assume it would be a very good idea to add radiused edges to the cutouts (so they have a throat like a velocity stack). Is that correct?
Matt
Old 07-03-2013, 01:59 PM   #4 (permalink)
Sports Cars
Pickups
Yes, radiused edges are always betterin re to airflow being smooth.
