Old 11-17-2021, 12:18 PM   #11 (permalink)
* Also, from fluid mechanics, it's been demonstrated that, for 'subsonic', non-compressible flow, a convex- hemispherical nose is perfectly acceptable to guarantee fully-attached forebody flow. So I de-lengthened the traditional cod's head of a streamline body-of-revolution-based half-body, figuring that it wouldn't impact flow, would reduce overall body length, save weight;......
Apparently I had it backwards then, template was shorten not lengthened, not sure if all that was ever posted or just what you dealt with in the backroom.
A poster named Tesla back in 2013 was attempting to use or compare to NACA 0039 profile. This had a longer Cod's head.
I was the one that did an overlay, not that I recall doing so.
Link to green template overlay attached below:
https://ecomodder.com/forum/showthre...c-9287-56.html
EDIT:
Interesting thread, possibly related.
2013
Bluefin Tuna Template, is this it?
https://ecomodder.com/forum/showthre...ate-24759.html
Quotes from the 2013 Bluefin Tuna thread.
https://ecomodder.com/forum/showthre...e-24759-2.html
*It looks like the side elevation of the vehicle should stay close to the 'Template' and then for plan-view,since the vehicle is 'narrow',lean towards the 4:1 'Section' and do our best to blend it all together.
........Yeah,it's a bit of a joke to presume that for so many types of vehicles manufactured that there would ever be a one-size-fits-all template..............
Poster "Tesla" posted some of this workings here:
https://ecomodder.com/forum/showthre...c-9287-72.html
Name:	Template Part-C.jpg
aerohead (11-17-2021)
Old 11-17-2021, 12:43 PM   #12 (permalink)
NACA 0039
Link to green template overlay:
EDIT:
2013
* Some 2-D flow wing section profiles happen to coincide with contours found in 3-D flow streamline bodies of revolution which I've concentrated on.
* Both are correct for their operational environments and performance specification. And there's always a tradeoff somewhere.
* If you look at what Fachsenfeld and Kamm did to Walter Lay's 1933 half-body, you'll also see a smidgeon of alteration between the two.
* The important thing for us amateurs would be:
1) If you happen to realize that your vehicle's contour happens to match that of a 'known quantity' streamline profile....
2) And you intend on elongating the body for lower drag....
3) Stay on that identified contour when you do it, otherwise you invite separation, negating the whole process.
