Old 09-18-2018, 02:55 AM   #1 (permalink)
42 lb per Sq In. tires and headlights keep burning out
On my Gen 3 Prius, I get the best MPG with the tires at 42 lbs, but road bumps knock out my headlight bulbs. Is there a way to cushion the head lights, tail lights, running lights, etc, from the road shock the harder tires give?
Old 09-18-2018, 04:11 AM   #2 (permalink)
Not sure how they're mounted on the prius, but maybe rubber washers on the headlight mounting bolts (between the body and the light unit?)
Chris
Old 09-18-2018, 10:26 AM   #3 (permalink)
If your getting Sylvania at walmart they are only rated 200 hours. Last one I replaced I got 212 hours based on my average speed and miles. I have 4 Hella long life waiting on the shelf $3 each. Rockauto has a large selection.
Old 09-18-2018, 10:49 AM   #4 (permalink)
I'm getting whatever the Toyota shop puts in. The shop recommended HID, but that's VERY expensive!
Old 09-18-2018, 11:14 AM   #5 (permalink)
Let some air out of the tires.
Breaking stuff to save a little gas is only going to cost more $.
You are likely in the process of breaking other stuff too.
Old 09-18-2018, 11:31 AM   #6 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
+1 oil pan 4
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 09-18-2018, 02:17 PM   #7 (permalink)
But, the question is how can I stop breaking bulb filiments, AND keep the better MPG?
Do you have a better answer than "Give up the MPG"?
Old 09-18-2018, 02:20 PM   #8 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Get HIDs
The bulbs start at around $10. A full conversion kit can be had for less than $40.
Old 09-18-2018, 02:21 PM   #9 (permalink)
Get LEDs.
Prepare to spend money on the next thing that breaks.
Old 09-18-2018, 03:26 PM   #10 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
LEDs will do great. I usually get stuff from Super Bright LEDs website.
42 PSI isn't even hard, that's probably not even above manufacturer sidewall limit depending on the tire. Are roads really bad in your area? I could see problems if you lived in Detroit for example, those roads are the worst.
