Go Back   EcoModder Forum > AltModding > Saving@Home
Old 02-04-2018, 01:01 PM   #41 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
The only disadvantage I can think of is your led never burns out, so you keep using say 60lumen per volt amp lights even as 150+ lumen LEDs come available, because your old ones just won't die.
But they *do* put out reduced light. So another disadvantage might be sitting in the dark!
Old 02-26-2018, 05:01 AM   #42 (permalink)
I bought some cheap 100w replacement LEDs from lowes.
Only 50 lumen per volt-amp.
So far these are the worst.
I thought leds were supposed to be getting more efficient.
Old 02-26-2018, 05:07 AM   #43 (permalink)
Sunday I brought out a cheap Harbor Freight dual flood light to work on the car. One of the halogen bulbs went out. What an annoying hassle. I'd pay more up front to not have to replace bulbs and save electricity.
I have some halogens using iodine some how, a "300w improved efficiency" tube only uses around 220w.
Old 02-26-2018, 06:31 AM   #44 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
People are going to buy them because they're cheap and because they're "better"...and assume that they will automatically be more efficient. (and, compared to an incandescent, even the cheap LEDs will be)
If you want more efficient, you might have to actually pay for it.
Old 02-26-2018, 06:49 AM   #45 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
https://www.amazon.com/gp/aw/d/B01MS...9eL&ref=plSrch
You don't really have to pay more. Just check the specs before you buy...
Amazonbasics 100w equivalent. 1400 lunens, 14 watts. Amazonbasics is their bargain brand.
Old 02-26-2018, 06:56 AM   #46 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Almost all the lights in my house are leds, I have been replacing the existing lights/fixtures as they burnt out. I only have a couple of halogens in the utility room and 3 zenon puck lights to replace. Even the lights in my shed are led now.
I've had the led can lights in my family room and kitchen for at least 8 years and haven't replaced one yet, and if they're putting out less light now it's not a noticeable difference.
Old 02-26-2018, 09:39 AM   #47 (permalink)
Yeah that's pretty close to what i have, a 100w replacement, that "uses" 16watt and 32Volt-amps.
Its not the LEDs fault the rest of the assembly is so inefficient, the LED it's self would run a 99+ power factor on low voltage AC power. The very cheap power supplies are cheap at the cost of efficiency.
It's the cheap power supply killing efficiency.
Old 02-26-2018, 11:35 AM   #48 (permalink)
Thalmaturge
Amazon does give power factors on their UK site.
https://www.amazon.co.uk/AmazonBasic..._1519662635464
0.5 for their 60w equivalent bulb. Yuck.
Old 02-27-2018, 11:06 AM   #49 (permalink)
My electronic ballasts for T5 tubes runs a 96% power factor.
The tubes are fairly efficient, but the power supply is very efficient.
Pretty sad that T5 has been doing 90 to 110 lumens per volt amp since the early 2000s, yet gets a bad wrap for being "inefficient".
Old 02-27-2018, 11:27 AM   #50 (permalink)
Stubby79's Avatar
It does? We still run T5s at work, and had them completely re-done just a couple of years back.
As a consumer, I like knowing I don't have to take any special precautions win an LED bulb. In fact, the ones i have are not only non-toxic, they're pretty indestructible. Perfect for my work/trouble light!
led
