Old 02-25-2019, 05:42 PM   #41 (permalink)
Originally Posted by 19bonestock88 View Post
I’m fairly certain that my bad 3rd synchro is related to going 1-3-5 the first 25k I had the car before the problem surfaced
Oh, oh! Since I've been skipping gears for half a million miles, I'm way over-due for manual transmission probs. Since ah'm addikted to skip-shifting, ah don' thunk ah ken brake ma habit.
Maybe, I'll get some automatic cars & throw away my manual shifters. They can't be good with so much gear skipping.
Old 02-25-2019, 06:26 PM   #42 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
I find myself doing 1-2-4-5 or 1-2-3-5 often, depending on the incline. Maybe I should stop in case of excessive transmission wear from it..
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 02-25-2019, 07:13 PM   #43 (permalink)
The 'Coupe has been frequently skip-shifted since 2000. Still works good so I'm not going to stress about it.
deluxx (02-26-2019)
Old 02-25-2019, 10:49 PM   #44 (permalink)
Luddite
deluxx's Avatar
ol-green - '96 Honda Civic LX
90 day: 50.11 mpg (US)
say if you never use a gear because you skip shift it cant wear out right?!
Old 02-26-2019, 06:09 AM   #45 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
If you rev match skip shifting causes no wear, in fact it saves wear on the gears/ syncros you're not using, particularly if you alternate which gears you skip (difficult in a 5 speed- easier in a 6).
Same goes for the clutch, shifting is probably responsible for around 1% of total clutch wear (assuming a good driver), but fewer correctly matched shifts equals less wear. Less wear on the clutch hydraulics, throw bearings, shift fork, shifter bushing and cables etc -any of which can also go bad in time.
Also, 2nd tends to be the first syncro to die as it generally lives the hardest life, so if you could skip it half the time, you could double your gearbox life.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
deluxx (02-26-2019)
Old 02-26-2019, 07:15 PM   #46 (permalink)
Originally Posted by oldtamiyaphile View Post
..... 2nd tends to be the first syncro to die as it generally lives the hardest life, so if you could skip it half the time, you could double your gearbox life.
I like that, fer sure.
