Old 12-07-2023, 10:56 AM   #1 (permalink)
Winter blend gasoline
So here is some proof of how fuel vaporization matters…
A 33% improvement just running the winter bland gasoline which has a more ability to vaporized easier.
“In winter, gasoline blends have a higher Reid vapor pressure, meaning they evaporate more easily and allow gasoline to ignite more easily to start your car in cold temperatures.” https://www.gasbuddy.com/.../summer-blend-and-winter...
The change from 15MPG to 20MPG is 5 MPG improvement, that is .33% improvement, that is a major change.
So has anyone tried to FIX summer blends??
I discovered this when I took my 03 Explorer up to road speed, which is 75MPH posted and of course I was running along with traffic at 80MPH.
And on a scan of all my gauges I saw what seemed impossible, she was doing 22MPG: 22MPG at 80MPH…this did not stay 22 as load as other things acted on the SUV but it stayed at 19 to 21 all the way back to home…even when I kicked in the A/C. This was a drive of about 9 miles.
I took her out again the next day and it was still reading 18/20MPG at 70/80MPH….this does not compute.
All summer long she was reading 50MPH = 28/32MPG, 65MPH = 18MPG, 80MPH = 15/16MPG.
So this morning at 3PM I woke and wanted to test her a fully as I can….so first thing I checked was my scan gauge II was still set for a 4.6 engine… I thought it might had reset its self to different engine size. It had not, it still reads a 4.6.
So up on the freeway and ran normally until all was warmed up, then began testing on the return leg of the trip…
50MPH = 29/35PG, 60MPH = 22/23MPG, 70MPH = 21/23MPG 75MPH = 21/23MPG even 80MPH was showing 20+MPG WTF!!!???
The really odd thing is my 50MPH reading of 29/32MPG is the normal reading I have been getting, it is the readouts for above 60 that are off….the 10MPG drop at around 60MPH seems to have disappeared somehow.
Seemly thanks to the winter blend, anyone else seem this happen??
I have had a couple of people confirm this.
Rich
Old 12-07-2023, 11:35 AM   #2 (permalink)
Focused on MPG
Marinator - '06 Mercury Mariner Premier
90 day: 20.86 mpg (US)
SILVER BULLET - '19 DODGE GRAND CARAVAN GT
90 day: 19.4 mpg (US)
Myrtle - Wife's JKU - '12 Jeep JK Unlimited Sport
90 day: 15.34 mpg (US)
KK Copperhead - '05 Ford Escape XLS
Running with traffic
When running with traffic at a set speed, a lot of the air that you would normally push at higher speeds has been dissipated by the other vehicles going through the same space, when that happens, a lot of the pressure has been reduced (think tailwind pushing your car forward).
I am sure some of the more technical gurus can explain this better!
Staying Focus'd on MPG
Old 12-07-2023, 02:35 PM   #3 (permalink)
There were almost no cars near me, and it happened three times. Three different days.
No either the truck changed or the winter blend is giving it more MPG...
Rich
Old 12-07-2023, 05:11 PM   #4 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Your link doesn't work - any chance you can re-post it?
Old 12-07-2023, 05:38 PM   #5 (permalink)
What link?
Old 12-07-2023, 05:41 PM   #6 (permalink)
Originally Posted by racprops View Post
What link?
You put a quote in, and had a link right after it, presumably as the source of the quote.
Old 12-07-2023, 07:00 PM   #7 (permalink)
https://www.gasbuddy.com/go/summer-b...blend-gasoline
Rich
The Following User Says Thank You to racprops For This Useful Post:
Ecky (12-07-2023)
Old 12-07-2023, 07:04 PM   #8 (permalink)
Thanks!
Overall, the article says that gasoline blends are adjusted seasonally to make sure it can vaporize effectively enough in a completely cold engine that hasn't fired yet.
