Old 10-07-2012, 08:09 PM   #1 (permalink)
AbeisAverage's Avatar
Second time's the charm - '04 Honda Accord EX
90 day: 24.26 mpg (US)
Tengu - '11 Mazda Mazdaspeed 3 sport
90 day: 19.73 mpg (US)
How to Paint Chloroplast?
I recently put a grill block on my car. I was just going to paint it with some general spray paint. The thing is it's starting to get too cold for that kind of thing, should I just wait until spring or are there other paints I might want to look into?
Old 10-07-2012, 08:35 PM   #2 (permalink)
sid
grayranger - '10 Ford Ranger XL 2 door supercab
90 day: 31.78 mpg (US)
Coroplast. I've painted it with just regular enamel paint and it seems to hold up and doesn't melt the plastic.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
Band's latest song/music video "I Sing Along"
Old 10-07-2012, 08:39 PM   #3 (permalink)
Ha, too much science lately. But thanks.
Old 10-07-2012, 08:44 PM   #4 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
I painted mine with automotive paint. The areas that don't get touched have stayed painted. The areas that got touched during install probably still at that point were it was dry to the touch but still not dry. my wheel covers could use another coat but my grill block is still perfect
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 10-15-2012, 03:04 PM   #5 (permalink)
This is about gluing rather than painting coroplast, but might apply:
How to Glue Coroplast
Blame it on your spell-checker.
Old 10-15-2012, 03:59 PM   #6 (permalink)
Ecomoddically recovering
Pandaf's Avatar
Pandamera - '06 Fiat Panda LPG
90 day: 39.21 mpg (US)
If you don't care about the colour then black underbody coating can also be used. Spray a thin even layer on the material. The advantage is that it stays flexible and is easy to touch up if necessary later.
Old 10-15-2012, 04:02 PM   #7 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
I used Krylon paint on mine, it was the "fusion" paint meant for plastic and it worked great.
Old 10-20-2012, 11:47 AM   #8 (permalink)
The PRC.
On my old grill covers I painted them white to match the car just for fun, I'm leaving the current ones black.
First cleaned them off and rinse, then used an adherence promoter, light grey primer and then white.
Temp seems important in promoting the paint to dry effectively, even if you paint outside and then put it near a radiator inside.
grill block, paint
