01-24-2022, 07:04 PM
#11 (permalink)
It uses cookies!
I normally use Vivaldi, but I keep Brave open because some sites work better there.
Like KBB.com.
In Vivaldi it tells me to turn off my ad-blocker. I can delete that element, but I need to delete it on each and every page before I can get a vehicle's estimated value.
I swear that I once had an ad blocker set up to block those.
It just loads on Brave, yet I don't see any ads.
Oddly, it only loads one screen at a time!
I was blocked by WMICentral.com in Vivaldi a few days ago, but was able to read a couple of articles in Brave. Once I was blocked I looked at my cookies and found 3, each set to expire in a week, so I get 3 articles per 7 days?
I deleted the cookies and loaded another article.
That is easier than telling my browser to capture the screen before it loads the paywall and viewing in Paint!
I set a rule to delete cookies from www.wmicentral.com each time that I close the tab.
Well, that is one site!
02-10-2022, 01:35 AM
#12 (permalink)
Enabling God Mode in Windows 10\11
This explains how to create a folder on your desktop, copy and paste a string, and enable easy access to power features, many of which are much more difficult to access: https://www.techspot.com/amp/article...dows-god-mode/
02-10-2022, 01:47 AM
#13 (permalink)
In the context menu, select "Create shortcut." Windows will then tell you that a shortcut cannot be created there and ask if you want it on the desktop instead. Select "Yes."
I thought they were called symbolic links in Windows.
https://docs.microsoft.com › en-us › windows › security › threat-protection › security-policy-settings › create-symbolic-links
A symbolic link is a file-system object that points to another file-system object. The object that's pointed to is called the target. Symbolic links are transparent to users. The links appear as normal files or directories, and they can be acted upon by the user or application in exactly the same manner.
.What the headline giveth, the last paragraph taketh away. -- Scott Ott
06-28-2022, 06:29 PM
#14 (permalink)
That webpage editing hack is unnecessarily complicated--like this title! :D
I regularly share articles and provide screenshots, but I also regularly find errors in professional publications. One was especially bothering me, so I right-clicked, hit Inspect, found the grammatical offense, edited it, hit Enter, and it made the change.
The problem that I have had with the hack Linus shared is that it then spell-checks the entire page, so either I add random names and words to my dictionary, or share screenshots with broken red lines for no reason. I am not saying this ever happened, just showing how easy this is:
06-28-2022, 07:00 PM
#15 (permalink)
Xist isn't half bad.
When I first saw that LTT logo I hadn't heard of Libs of Tik Tok.
I restarted the computer and lost all audio. I chased my tail for a few hours -- not a volume control, not redirected to HDMI, ???? Then I figured out that when you mute a tab in Chromium it mutes all the tabs.
06-28-2022, 07:50 PM
#16 (permalink)
I'm all bad?!
Chromium works in mysterious ways!
06-28-2022, 09:06 PM
#17 (permalink)
I didn't say that  but now I can put the quote in my sig line.
06-28-2022, 09:45 PM
#18 (permalink)
If you don't cite fake freebeard you're plagiarizing!
06-28-2022, 10:47 PM
#19 (permalink)
Let's talk about identity theft and misinformation on the sooper-cyber highway.
08-29-2022, 04:21 PM
#20 (permalink)
Donut Media reviewed TikTok automotive hacks with actual mechanics
There were a couple useful tips, a couple fails, and the rest was pure TikTok garbage--so normal TikTok.
The best part was that the annoying guy was paired with an old school mechanic who would have told him he was annoying, so he toned it down:
