Old 08-02-2009, 03:57 PM   #1 (permalink)
MPGuino resistance between +5V, ground
My MPGuino screen has been flaky, so I started looking for things to check. I found this thread which had dcb explaining to check the resistances on the LCD. I noticed that my pins 1 and 2 were only 11k Ohms. Thinking it was a bad solder job on the pins, I tried to remove them (but ended up scraping the PCB connection between pin 2 of the header and the voltage regulator. With this LCD pin now separate, I still get 11k Ohms between pins 2 and 3 of the regulator (+5 volts and ground).
Can someone check theirs and tell me what may be wrong? Thanks
mpguino, resistance, troubleshooting
Online tool: shows aerodynamic drag, rolling resistance, power required & est. MPG MetroMPG Aerodynamics 100 12-30-2022 06:25 AM
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
