Old 10-09-2013, 01:50 AM   #21 (permalink)
Legacy - '98 Subaru Legacy GT Wagon
Pie Slinger - '85 Honda CRX DX
Job is decent, picking up for winter. Almost have this CRX back together. Had the head milled, and should have it buttoned up tomorrow!
Old 10-09-2013, 03:32 AM   #22 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Ryland View Post
You would either need to install two fuel injection systems or install a different head and at that point you might as well do a full engine swap.
the CVCC head is amazing, but it does not work well with fuel injection because the main intake goes to the combustion chamber and the spark plug is NOT in the combustion chamber, it's off to the side with it's own intake that gets a rich mix of gas that then spreads to the lean mix in the main combustion chamber, when that is done the engine run cool and smooth, when you start messing with it you burn valves, you blow head gaskets and ruin engines.
The CVCC engine did other stuff, like fuel cut off on deceleration and had a factory warm air intake.
In Japan, there was a fuel injected CVCC engine. If I remember correctly, it was the EW5 engine used in the CRX/Civic 1.5i. It had a 5th injector for the aux valves/chambers.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 10-10-2013, 01:04 AM   #23 (permalink)
Got it back together today! Just need to replace the thermostat, as it was getting a little too hot when I took it out for a test drive(s). So tomorrow it gets a new t-stat(I pulled the one in there to verify it was bad), and off to emissions and the DMV. Hopefully she will be delivering pizza tomorrow night!
