Old 06-01-2009, 10:30 PM   #1 (permalink)
Vibe - '07 Pontiac Vibe
90 day: 47.11 mpg (US)
Hi, this is my first post here
I joined here some time ago and have been stopping back to read and soak up some of the wonderful knowledge found here.
stopping in tonight looking for info on the mpguino I just ordered.
and I thought I should say Hi before asking questions.
If there is a mpguino forum I will also post the question there.
Question:
If the engine is killed while gliding in the car what will mpguino show?
will it stop recording? To the point: Will mpguino show the mileage going up while the engine is off and car is moving?
Old 06-02-2009, 10:13 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Welcome! I think you already posted the question, so you found the right forum
Old 06-02-2009, 10:30 AM   #3 (permalink)
Welcome to EM.
The MPGuino will indeed track mileage weather the car is on or off. When it is wired, it is wired into a constant 12V source, so it never turns off (only the backlight turns on and off).
Edit: I should clarify. The MPGuino will track mileage weather the car is on or off. However, if the car is off (key in the OFF position), there is no voltage going to the speed sensor, so the guino gets no signal and thus can not track mileage. As soon as you turn the key back to on, the sensor has voltage and the guino continues to log. This can all be avoided with a kill switch though.
Old 06-02-2009, 11:21 AM   #4 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Welcome fellow Minnesotan!
Good to see you making your way around the site already.
Be sure to add yourself to the Ecomodder Google Map.
Old 06-02-2009, 07:27 PM   #5 (permalink)
OK, I am on the map.
Not as many pins on the map as I would have expected. by adding my Pin I have doubled the count for Minnesota.
Old 06-02-2009, 08:04 PM   #6 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Welcome to EM, have a great read! (There's lots and lots and lots of stuff here to read... LOTS.)
Old 06-02-2009, 09:50 PM   #7 (permalink)
Ok, got a few tanks in less see if I got the signature right
Old 06-02-2009, 09:56 PM   #8 (permalink)
Wooooo Hoooo It worked.
Old 06-03-2009, 11:20 AM   #9 (permalink)
That VX guy!
TomO's Avatar
Yeah, there are about 4-5 other users in MN but they haven't posted their pins
Congrats on getting your MPG signature setup too.
The BSFC chart thread (post 'em if you got 'em) MetroMPG General Efficiency Discussion 302 05-03-2022 03:20 AM
EcoModder 100,000th Post Giveaway Spectacular!!! SVOboy Forum News & Feedback 35 05-09-2009 01:58 PM
"Start New Thread" icon at bottom of each post??? TestDrive Forum News & Feedback 5 03-17-2009 04:09 PM
Battery Post Repair bennelson Fossil Fuel Free 4 10-17-2008 03:35 AM
