Old 02-10-2011, 11:03 PM   #1 (permalink)
Low and Mean's Avatar
Looking for a MPG gauge for old truck
Hello, I have a 92 diesel box van and our company is on a mission to make this van as efficient as possible. To start testing different ways to make this van better we need a gauge that will show our MPG. This van has almost no electronic, there's no ECU/ECM, it's a 1992 E350 7.3L IDI no Turbo. I was wondering if there is a system available for our model, or something we can retrofit. Thanks for your help, we are very new to the forum, but I can see me spending a lot of time here.
Chris
Old 02-11-2011, 12:50 AM   #2 (permalink)
I think you can get started right now by keeping a fuel log. Instrumentation is quite nice but I don't have any...
Old 02-11-2011, 12:15 PM   #3 (permalink)
Yes, we do this but I want to see the results as I drive, as I also believe this will help improve my driving. Plus I can see the optimum range.
Thanks for you suggestions.
Chris
Old 02-11-2011, 12:16 PM   #4 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
You need a Floscan diesel flow meter...
Old 02-11-2011, 01:21 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
It's been talked about a bit, I've never gotten it to the front burner though, mebbe this spring.
http://ecomodder.com/forum/showthrea...html#post86551
Old 02-11-2011, 05:13 PM   #6 (permalink)
What kind transmission it have and what gear ratio in rear axle.
My 87 F250 get 18 mpg on highway that with manual tran only 1.00 plus 3.55 in axle it see 2500 rpm at 65 mph.
Biggest is alignment and air tires to max psi. I believe it 60 psi for rear dually.
Get very slow kick off from stop or you waste diesel.
Old 02-11-2011, 06:20 PM   #7 (permalink)
dude...wait...what?
Odin's Avatar
Diesel Rx-7 - '82 Mazda Rx-7 GSL
merc 300d - '82 Mercedes-benz 300d dt
b2200 diesel - '84 Mazda b2200 D
have you considered turbo charging it? I hear na 7.3 gets worse fuel eccon when loaded down compared to a turbo one
Old 02-11-2011, 09:56 PM   #8 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
The 7.3L IDI is a good engine. I suggest a fuel flow meter, but just reading the eco driving tips here will help you a bit. A Banks turbo kit would be good, I think.
Old 10-31-2011, 12:44 AM   #9 (permalink)
Thanks for your suggestion. We did get a turbo and innercooler with propane injection put on this van.
LM
This Low and Mean 1992 ford box van has a turbo, innercooler and propane injection. Then we covered the rear wheels and wrapped the van with a 12" rubber skirt. The big front bumper we made out of fiberglass with a rubber skirt below. The end result we took a van from 10-11 mph to 14-15 going 60-65 mph.
Thanks to all the great tips that helps us build this van.
