Old 04-12-2010, 02:49 AM   #11 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Yes, the '02 and newer US Spec Altimas use the same 2.5 L engine that's in the Spec Vs. The 2.4 L truck engine that's in your '00, combined with the previous generation's smaller size, give us close to the same EPA ratings. I've gotten half a dozen 45+ mpg tanks, so you may be able to match me, especially if you have a manual transmission. If you don't, you won't, and you shouldn't be EOCing.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 04-12-2010, 09:55 AM   #12 (permalink)
Altee - '00 Nissan Altima GXE
90 day: 31.82 mpg (US)
Just thinking out loud as I'm not planning to do this for another month or two, with a full grill block and and belly pan would header wrap help the fan from kicking in as much/long? I realize the engine temps are going to be just as high but it might keep the engine compartment cooler allowing the rad to be a bit more efficient.
And yes its a five speed manual
Old 04-12-2010, 11:59 AM   #13 (permalink)
Pishtaco
SentraSE-R's Avatar
Header wrap should help keep the engine compartment temperatures down.
If you can keep your freeway speeds down, your long commute should allow you to achieve a high 30 mpg average, I would think. Slowing down accounts for about 75% of my mpg improvement. Advanced techniques like P&G and DWB account for the remaining 25%.
Darrell
