Old 01-06-2013, 04:49 PM   #71 (permalink)
Just happened to turn the computer on for the first time in several days and there was your message! (Its 10:00 am on Monday here).
The shunt resistors are 4 x 1 watt, 6R8 smds connected in series/parallel to provide a single 6R8 resistor capable of dissipating up to 4 watts. They are connected across the module supply terminals in series with a transistor that is turned on or off by the micro.
You would have to re-arrange the circuit so the voltage divider feeding the micro etc is separated from the shunt. Also, feeding say 15V into those shunt resistors would cause lots of melting! ie 33 watts.
The power dissipation of the shunts is something to be considered carefully and the Li cell circuit dissipates 1.9 watts when shunting at 3.6 V. This is about the max that can be tolerated in that small space. For the same dissipation from a 15V battery, you'd need to change the resistors to 120 ohms and then you'd only bypass .125 A which is not much to try and do balancing with. If you want a shunt current of 1/2 amp, then you need 30 ohms and dissipate 7.5 watts, so need 15 - 20 watt resistors! Or a heat sink. So that's what I mean when I say you need to change the shunting.
I use DesignSpark for schematic and pcb files. You can download it free from their web site.
The C code is all compiled with the CCS C compiler running under MPLAB.
I'll be sending Mark some updated files shortly.
Sometimes I sits and thinks and sometimes I just sits.
Old 01-06-2013, 06:15 PM   #72 (permalink)
Thanks again for the speedy reply! Super glad you turned on your machine! Thanks for all the information it is really appreciated. I think this could be a really neat project. But, I would like to keep with your original idea of a simple BMS with keeping the costs as low as possible.
I am going to work on the voltage divider first, then the shunting. Just an FYI, I am jumping into the deep end. I have done a bit of simple circuit design. But, I love the idea of a challenge!
I was thinking it would be good to be able to shunt 1-2 amps max like your original design. Seems like that would be some serious heat at 15v which like you mentioned would need a complete rework of the shunting approach which most likely would include some sort of heat sink.
I took a look at the wiki, you don't happen to have a copy of the schematic file I could muck with do you? Or, maybe if you don't mind providing an editable file to Mark for the wiki?
Doug
Old 01-06-2013, 06:25 PM   #73 (permalink)
Send me a pm with your email address and I'll send you the current files.
Old 01-06-2013, 09:51 PM   #74 (permalink)
Thank you for the files harlequin2! I am working on the voltage divider now and will hopefully post an updated schemtic for AGM's soon.
I found this link googling voltage dividers:
www DOT electronics-lab.com/projects/test/016/index.html
Looks like this divider would work well!
Doug
Old 01-07-2013, 01:59 AM   #75 (permalink)
Nice work on the BMS !
I to would be interested in Pb BMS.
I am using 9 AGM 12V / 100Ah for my car.
Keep up the good work !
Old 01-07-2013, 03:06 PM   #76 (permalink)
I'm not interested in PbA batteries myself as I think they are a complete waste of money as far as powering an EV is concerned! However, I have sent my files to dcarlson and he is keen to develop a version for these batteries, so watch this space and hopefully he will give us updates on his progress.
Old 02-16-2013, 07:20 AM   #77 (permalink)
Some alternative ideas
Hello everybody,
harlequin2, when I came across your BMS design, I really loved the daisy chain
idea - full isolation and two way communication possible while being
really cheap - excellent thing.
While reading this thread I came across three ideas - maybe we could
discuss them?
1. Use only transistor in a TO220 package for shunting
This would mean that the module would have to be calibrated (the MCU would have
to output the right voltage for the MOSFET to pass for example 1A), but we
could screw the transistor to the positive battery terminal and have it dump
the heat into the battery.
Advantages:
- higher shunting current possible
- it could double as a cell heater for winter charging (but the currents of all
the shunts in the system would have to match closely) when fed from the
charger
- less component count
Disadvantages:
- current calibration step required
- possible thermal coefficients issues (the Vgs / Rdson curve)
- DAC or PWM (and a low pass filter) required from the MCU
- TO220 case component possibly more expensive than SMT
The calibration could be a feature of the control unit.
2. Use optical link in the daisy chain setup
Your project used transoptors connected with cables.
How about replacing the cables with a ray of light?
Example:
(please replace spaces with slashes)
Batteries from GBS like GBS-LFMP60AH
have a cool feature - they have bumps and corresponding holes on sides of their
casings so that when you make a pack out of them then they are nicely aligned.
This means that if we put the pack together then we could just have diodes and
phototransistors on adjacent modules' sides and just shine from one module
to another. It should be quite reliabe on such a short distance, especially
with short tubes mounted on photo elements (to narrow down the angles).
We would have to have mounting points for both phototransistor and
diode on each side so that we could link them disregarding orientation.
The only problem is joining ends of battery strings - we could go
back to wire there or use something like toslink (2 or 3 pieces
should not drive the cost up very much).
Your battery pack would not gain much from this setup
(parallel-series combination), but I plan
to have two or three long strings of batteries in series and
this could work out nicely.
Advantages:
- less wiring
- less connectors
- vibration/time wear resistant
- easy "loss of link" debugging - just look at your
pack with a camera - IR will show up as white
- better EMI resistance
Disadvantages:
- possibility of interferences between links
- better battery alignment required
- slightly higher power usage (IR diode vs transoptor diode)
- communication might be slower
- IR diode and photo transistor combo might be slightly more expensive
than a transoptor
- better electrical isolation
3. Use optical link in a star configuration
We could put an IR diode and an integrated IR receiver
on each module. Let's say we'd emit 26kHz with the diode and receive 40kHz with the receiver
to reduce interferences between sending and receiving sides.
Then we could have one additional module in the battery box which would emit
40kHz with an IR diode and receive 26kHz with a receiver.
IR protocols like RC5 seem very robust (more than 10 meters with the daylight),
so communicating over 1m in a closed box should be trivial.
Advantages:
- no wiring
- no connectors
- module connectivity does not affect other modules
- asynchronous alarms from the modules with a good IR protocol
- perfect electrical isolation
Disadvantages:
- needs a bit of space over batteries for the light to pass
- higher cost of an IR diode and a receiver (compared to a transoptor)
So, what do you think of these?
Also a question - the battery terminals visible in post #43
look like they were reinforced with something like tubular rivets.
Can you share some details on this?
Old 02-16-2013, 07:34 AM   #78 (permalink)
And one more thing - I have developed an MCU (attiny) based module for cars
which communicated with a main board over a 9600bps RS232 (TTL levels).
I had used the internal RC oscillator to clock the MCUs and it resulted in a failure - when the temperatures outside dropped below around 0 degrees C, I was unable to communicate with some of the modules, because the RC clock
drifted too much and the main unit could not understand RS232 frames
anymore.
I had to come up with a second revision of the module with a crystal clock.
Your design seems to use an internal oscillator - do you have any precaution worked out for this issue?
Old 02-16-2013, 05:38 PM   #79 (permalink)
First off, you can't use a fet as a load without some form of stabilisation - simply applying some voltage to the gate results in a completely unknown and quite unstable current flowing. "Calibration" as you suggested does not work, it is simply too unstable to be even thought about.
I did experiment with using photo-emitters and receivers in lieu of wires and optocouplers, but have not been able to obtain reliable results and I wanted a working bms in my car, so that idea has been temporarily shelved. One of these days I will re-visit it.
Item 3 - I don't understand how the addressing might work.
No rivets used on the pcbs, I think you are looking at some solder on the plate dthrough holes.
The internal oscillator in the PIC is +- 2% from 0 to 60 deg C and only +- 5 % down to -40 deg, so its much better than the AVR R/C oscillator. It is stable enough for the RS232 to work over that temp range.
Old 02-16-2013, 06:07 PM   #80 (permalink)
And a feedback loop would kill the component count gain, so I guess the idea goes down the toilet.
We start with assigning a one or two byte integer to each board as an address and then query them one by one in a loop (M - battery module, C - main controller):
C: battery no 27, report status
M27: voltage is 4.18V, temperature is 28C, shunt is off
C: battery no 28, report status
M28: voltage is 4.21V, temperature is 28C, shunt is on
We need a kind of a board -> battery location mapping (to know which cell actually has the problem) anyway.
Address could be assigned over IR during an initial setup phase (a new module would have to be introduced face-to-face to the main controller) and saved in the battery module EEPROM.
That explains a lot .
Thanks for the feedback on the ideas.
