Old 02-13-2015, 02:53 AM   #11 (permalink)
Eddie25's Avatar
Fiesta - '06 Ford Fiesta 1.4 Ambiante
90 day: 45.9 mpg (US)
Dakar - '03 BMW f650 GS Dakar (retired)
Tucson - '07 Hyundai Tucson 2.0 GLS
90 day: 32.67 mpg (US)
Originally Posted by Old Mechanic View Post
02 sensor getting tired?
regards
mech
how would the O2 sensor effect FE? my engine light has been on for a while now needing the left bank o2 to be changed however I am still getting very good millage so im not in too much of a rush to replace it
Old 02-13-2015, 09:00 AM   #12 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Originally Posted by 2000mc View Post
jinx
Lol
The primary O2 controls A/F ratios, the secondary just measures catalytic converter efficiency on most cars. Your check engine light is probably just the "cat inefficiency" code telling you the sensor or the cat is not up to par. Either way it won't effect the way the engine runs. Front O2 would probably only cause a rich or lean cod which would impact FE. .
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
Eddie25 (02-13-2015)
Old 02-13-2015, 01:56 PM   #13 (permalink)
darcane's Avatar
do you know what your fuel trims are running?
When you fillup, does your gauge agree with the actual fill as well as it did previously?
Ran in this morning with long term fuel trim gauge active. The gauge reports percentages from -100% to 99.2%, my car was at 1.5-2.3%.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 02-13-2015, 01:59 PM   #14 (permalink)
darcane's Avatar
Originally Posted by spacemanspif View Post
I had a wandering idle in my Saturn but it was "searching" any time it was idling in closed loop, turned out to be the fuel pressure regulator was leaking gas into the vacuum line. If your gas pedal feels a little sticky your TB could be dirty, which could also mean your IAC could need cleaning like KSA said.
Could be a lot of things, what is status of tune up stuff? Plugs, fuel filter, etc.
Plugs were done a couple years ago and looked fine when I had the head off, fuel filter is inside the tank so I haven't replaced it.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 02-13-2015, 02:21 PM   #15 (permalink)
darcane's Avatar
do you have a vacuum modulated fuel pressure regulator? leaking regulator would explain poor actual mileage, while electronics report best ever
Electronics are reporting crappy mileage though....
I can keep the mpgs high on the freeway (I P&G between 50-65mph as long as traffic allows) , but when I get on side streets it plummets. My last tank was 39.2mpg per the pump and odometer; the Ultragauge reported 38.9mpg for the tank.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
