Old 06-07-2011, 11:23 AM   #1 (permalink)
rjacob's Avatar
2017 Honda Civic LX - '17 Honda Civic LX
90 day: 39.92 mpg (US)
Installed a front lip
I found it on eBay for $40 with shipping, decided to give it a try. It lowers the underside of the front bumper by about an inch. So I think it might prevent some air from going under the car, and improve the aerodynamics.
I think it looks kind of cool anyway.
I need to reinstall the partial grill block. I removed it when I was having issues with overheating. Turns out I had a blown head gasket. Not sure if the grill block contributed to the blown head gasket or not...I will most likely install a less aggressive grill block.
GreenCarMPG.com
Old 06-11-2011, 01:41 AM   #2 (permalink)
Mr2 - '85 Toyota Mr2 built turbo
90 day: 24.99 mpg (US)
Si - '08 Honda Civic Si
90 day: 32.91 mpg (US)
Well if it doesn't change anything at least it looks better.
Old 06-11-2011, 03:15 PM   #3 (permalink)
The PRC.
On the grill block I have had mine completely blocked with no issues, so you may have triggered an event due to happen to happen sooner but not caused it IMHO.
That dam looks good though.
Old 10-13-2014, 10:18 PM   #4 (permalink)
I wouldn't risk blowin the engine instead I'd lower it a bit in combination with the lip
Old 10-14-2014, 05:19 PM   #5 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Nice find. It looks good and you may find it helps with mpg. One of my first mods was a ScanGauge so I could monitor engine temps accurately. Then I could start grill blocking with confidence that I would not damage my engine. Instant mpg really helps with Eco-driving too. It costs more than your air dam did but it is worth every penny IMHO.
P.S. Now you can extend your side skirts to match.
P.P.S. Be careful with that beautiful air dam come winter in Rochester.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
