Old 05-16-2009, 10:36 PM   #1 (permalink)
magnetic oil filters
ive seen a few things about improving an oil filter by placing a magnet inside the filter to collect metal shavings and the sort. what is everyones thoughts on this?
Old 05-16-2009, 10:38 PM   #2 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
My oil drain plug has a magnet that is sometimes worth cleaning. One in the filter might get smaller particles out of suspension.
Old 05-16-2009, 10:57 PM   #3 (permalink)
how strong of a magnet do you think would be good. kinda of curious as magnets are pretty cheap
Old 05-16-2009, 11:04 PM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Yes it will help, your rings and sleeves are ferris metal, along with your roller bearings, but the bushings are all brass and bronze, some lead alloys as well so you still need to change your filter and use one that picks up small particals, also a bit of the grit in oil is dust from the air that has passed your air filter.
Old 05-16-2009, 11:15 PM   #5 (permalink)
A strong magnet with a sq inch of surface should be fine. I found one stuck to my auto trans oil pan. External applications probably work, too, through thin steel.
Old 05-17-2009, 12:45 AM   #6 (permalink)
probably not a big increase in mpg if any but still would collect more contaminants from your oil. makes me wonder about fuel filter and radiator
Old 05-17-2009, 02:09 AM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
wmwinfield -
I just got a magnetic oil drain plug from here :
Magnetic Oil Drain Plug
I also have a hard disk magnet on the oil filter.
But I don't do it for MPG. I do it for (cross my fingers) old-car engine health.
CarloSW2
American Solar Energy Society
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
