Old 07-29-2010, 08:13 AM   #1 (permalink)
LRR winter tires
Well, I'm thinking ahead a little bit, but winter will be coming sooner or later. So, I am looking for winter tires for the Prius. I've been looking at the Nokian tires and they all claim to be LRRs. The Hakkapeliita R's claim to be "Extremely low rolling resistance".
Does anyone have any experience with these tires?
Any other suggestions for winter tires?
I'm replacing a set of General Altimax Arctics. They are honestly a great winter tire. I've been very happy with them, and their price is quite reasonable. However, they aren't LRR and you can tell when you put them on or take them off.
The Following User Says Thank You to Daox For This Useful Post:
Nevyn (07-29-2010)
Old 07-29-2010, 08:20 AM   #2 (permalink)
I see you can now filter by LRR on tirerack.com! Very nice new feature. This brings up two more tires for consideration:
The Pirelli - Winter 190 Snowcontrol Serie II which is currently for sale at closeout prices which is very attractive. The couple user reviews praise these tires.
Then there is the Michelin X-Ice Xi2 which seems to be a fairly high rated tire.
Old 07-29-2010, 12:25 PM   #3 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Thanks for starting this! I was planning on doing just the same.
Here's a question I have. My summer tires are 195/60-15's. The sticker on the door says I can use 195/60 or 185/65; both are listed.
Which size would be better for a winter tire? What if I only bought two instead of four?
Old 07-29-2010, 12:31 PM   #4 (permalink)
Yes, I have driven the Hakka R on my Mom's Prius, and they are very good at coasting. They are among the best LRR tires, period; not just good winter tires. They have 51PSI sidewall maximum.
The other winter tire that I have more experience with that is low rolling resistance is the Michelin X-Ice. These were better than my Yokohama Avid all-seasons, by quite a bit. The X-Ice also have 51PSI sidewall max.
Old 07-29-2010, 12:37 PM   #5 (permalink)
Skinnier tires are better for snow/slush since they tend to cut through it better vs ride on top of it.
You can go with two tires for better stopping and acceleration in a straight line (which is most of the time). However, with four you'll gain additional stopping power and cornering will be better.
Old 07-29-2010, 12:38 PM   #6 (permalink)
Have you driven with the Hakka Rs in winter Neil?
Old 07-29-2010, 12:59 PM   #7 (permalink)
Also, where did you get your Nokian tires? My local garage can't get them and TireRack doesn't sell Nokian.
Old 07-29-2010, 03:21 PM   #8 (permalink)
I only drove on the m briefly, and My Mom drove with them. They work well as winter tires.
I bought them from Chang Ho Kim, who is the guy who won the economy run with them, on his Honda CR-X HF. His garage is very local to me! :-)
Old 08-02-2010, 10:01 AM   #9 (permalink)
I just purchased the Pirelli Winter 190 Snowcontrol Serie II from tirerack. I had a hard time hunting down the Nokians and the only place I did find them they were over $100 each. The Pirelli's came in at $57 each... kind of hard to beat that.
Old 12-07-2010, 09:43 AM   #10 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
I've yet to put a winter tyre on the Scab,
But my Norwegian friend who lives in Sweden said that Nokian is about the best you can buy..
I may have to invest in a set if this weather continues over here.
Good luck with the Pirelli
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 04:24 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
155/80-13 tires (looking for LRR options) Daox EcoModding Central 69 01-10-2011 11:47 PM
Bridgestone Tires and LRR gone-ot EcoModding Central 30 05-04-2010 12:31 PM
