Old 06-19-2014, 02:40 PM   #41 (permalink)
Volvo 360 - '85 Volvo 360
Peugeot - '01 Peugeot 306
Made a start on the undertray by bolting some aluminium sheet to the rear. Will try to close off the sides, and above the leafsprings with some rubber sheets.
Should I put on some vertical fins, or would those only be there for looks?
The Following 2 Users Say Thank You to Joris For This Useful Post:
RedDevil (07-04-2014), UltArc (06-19-2014)
Old 06-19-2014, 02:55 PM   #42 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
The way I see it, there is a big step between footwell at the level of your diff and the aluminium sheet you added.
IIRC the smoother the transition, the least the drag.
But to steep an angle will add lift at the expense of drag.
Old 06-19-2014, 11:42 PM   #43 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Vertical fins will help. Man, that looks good.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 06-21-2014, 11:34 AM   #44 (permalink)
I got 36 MPG this week. I know it can be better because not even half of it was highway driving. Next week the turbo camshaft arrives, so interesting to see what that will do.
Old 07-02-2014, 05:51 PM   #45 (permalink)
Got some things done. Installed the turbo camshaft, what a joy to drive! Vacuum at idle is much lower, pulls better down low and idles better. I think (hope) the cam will save me some fuel.
Mocked up a cardboard partial kammback, will need your help on this in another topic.
Started thinking about smooth wheelcovers.
And finished my front undertray today.
Old 07-03-2014, 02:07 AM   #46 (permalink)
OldContinents
Wheel cover wise, I wonder if it won't be easier to start from steel wheels as they're designed for it, having the little lip on the side (and being magnetic ...)
Also, a good opportunity to go for narrower / taller tires if you can find second hand tires ...
Old 07-03-2014, 02:23 PM   #47 (permalink)
Yes, I am looking for another set of wheels. But at the same time, I will try to make some covers for these wheels. Better then nothing
Calculations showed a 300 rpm drop with taller (195-65-15) tires at 60 mph. Sure that doens't go unnoticed
Old 07-03-2014, 03:24 PM   #48 (permalink)
OldContinents
What's the wheel pattern ?
I seem to recall eco tires go up to 16 inches these days.
An other 300 rpm wouldn't scare that big 2,3 liters engine of yours ...
Old 07-03-2014, 04:24 PM   #49 (permalink)
Wheel pattern is 4x100, the same as most small cars have. Easy to find.
When driving, I can feel that I am 'overreving' the engine, and want to shift to 6'th gear, but it is not there.
Old 07-04-2014, 02:04 AM   #50 (permalink)
OldContinents
Volkswagen and Renault come to mind but still not the one and only size.
(Peugeot and Toyota are different for sure)
300 rpm drop seems like a lot, it's actually the ball-park between my 5th and 6th !
Is there a diesel variant for your gearbox / diff combination ?
I did a gearbox swap in my Mk1 Golf GTi back in the day using a diesel gearbox.
It didn't last long so I ended swapping just the diesel crownwheel and pinion in the GTI diff setup that has some inbuilt springs.
It made a big overdrive in 5th like 180 kph @ 4500 rpm.
