Old 03-20-2025, 05:16 PM   #21 (permalink)
90 day: 89.66 mpg (US)
Battery tech hasn't changed much physically in the last ten years. Smaller form, more protection, higher charge rates, but watt hours storage is still a physical mass characteristic
While the fundamentals haven't changed, the energy density and price have.
I have observed when OEMs specify a battery, they tend to either optimize for high current and durability at the expense of capacity (hybrids), or high capacity and density at the expense of C rate and cycle life.
As compared with 10-15 years ago, like-for-like batteries today often have 2-4x rated current output, twice the energy density, and are a quarter the price.
The two common options for Insight PHEV conversions are Samsung 49.5Ah modules, and Honda 5Ah modules. The Honda modules actually have higher current capacity and astronomical cycle life, but the Samsung modules are 5x as energy dense.
I personally sourced an older Panasonic pack (2013ish?) out of a Prius Plug-in, and compared with the 2018 Samsung modules, they're half as energy dense, but the price was right.
Old 03-22-2025, 01:30 AM   #22 (permalink)
A few days ago, talking with a worker of the local water and wastewater utility in my hometown while he was taking a break from work, and I was taking the dog for a walk, he said something about solid-state batteries which could be a good upgrade for current generations of EVs on a foreseeable future. I told him the only solid-state accumulators I knew, which are commercially available by now, are capacitors, which unfortunately don't retain charge well enough for longer times as a battery does. Well, unless some companies which already use EVs as service vehicles renew their EV fleets fast enough to retain some residual resale value and avoiding the battery losing its ability to retain charge, I could expect some EVs being worked around with lead-acid Optima batteries, despite their weight and volume...
Old 03-22-2025, 08:29 PM   #23 (permalink)
In many parts of the world, the used battery market is being flooded by healthy, inexpensive lithium. The battery cost for an Insight with 50 miles of EV range is around $1000us right now, and prices are still falling.
Chinese manufacturers already have semi solid state batteries being mass produced, which are less* likely to catch fire if abused, and have better energy density. There are low volumes of truly solid state cells floating around, but they're hard to come by. Realistically they're still 2-3 years off from being common.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
freebeard (03-23-2025), Logic (06-15-2025)
Old 05-19-2025, 01:48 PM   #24 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I did a search but was unable to find what I was looking for. Can you talk more about this?
The G1 Insight is a special interest car to me, and as such I follow developments on it pretty closely. On Insight Central, people have discussed options for making it a full efficiency EV. One challenge to reusing any of the existing drivetrain components is that the factory electric motor is connected directly to the crankshaft - they're a single rotating assembly. The motor cannot spin without spinning the crank, and vice versa. To put a clutch between the crankshaft and the motor would require putting a spacer between the two, which then moves everything around in the engine bay. The engine doesn't have much room to slide (looking at it from the front) left, and if it does, your exhaust and possibly some coolant lines won't mate to it anymore. If the transmission slides right, your axles don't fit anymore. These are relatively trivial issues, but on the face of it, for the gains being sought, it appears to be more effort than it's worth, considering what other options exist.
What does appear to be mechanically simple and straightforward - the G1 Insight engine and transmission mount positions, and the bell housing, are identical between every hybrid 1.0, 1.3L and 1.5L from 2000 through to today (2025). Which is to say, you could bolt the CVT from a CR-Z to the engine, and mechanically, everything lines up. Or, you can use the 3rd gen Fit/Jazz hybrid DCT, which has an EV mode. Or, you can use the G3 Insight / 11th gen Civic Hybrid / Clarity / 4th gen Fit / Jazz hybrid "gearbox" and use that. The axles slide into the transmission, the transmission bolts to the engine, and the mounts bolt to the chassis. The challenge becomes electrical.
But then, the stock Insight motor is only 14hp. The Clarity gearbox, for comparison, has a 200hp electric motor, and a clutch that allows disengaging the engine for EV-only operation.
Similarly, the 41% thermally efficient 1.5L in a 2025 Honda bolts directly to the Insight gearbox. Or, any other gearbox in the series.
Any combination of engine and gearbox can be (mechanically) used, and all options other than the manuals and old CVTs have provision for efficient EV-only operation. The "eHEV" gearboxes (if they can be called that) appear on the surface to be the most straightforward. In these, you just have an EV drivetrain, but also with an input shaft and clutch that allows an engine to add power to the system as desired. Turn the engine on and drive clutch to the wheels 1:1 in parallel to the 200hp electric motor. Or, toggle the engine on and off whenever to spin the generator and fill the batteries.
Honda is not unique in this implementation. It's the classic "series hybrid". Nissan uses something similar in nearly all of their hybrids, but they do away with the clutch and engine connection entirely. You have what is essentially a Leaf drivetrain, but there also happens to be a combustion engine and generator somewhere in the chassis that can add to the battery.
There was a discussion “elsewhere “ but all I coulD find was this
https://www.insightcentral.net/threa...f.94185/page-3
The Prius Prime uses a full speed full power dog clutch, integration to allow the ima and gasser to separate would be the issue.
The Following User Says Thank You to rmay635703 For This Useful Post:
Ecky (05-21-2025)
