Old 10-12-2014, 04:24 PM   #11 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
I don't own a ultragauge, nor do I own a car that can work with one. How quick does your AFR charge, and are you running a wideband oxygen sensor? I watch the oxygen sensor directly through a pin on my car's diagnostic connector, but mine is a narrowband oxygen sensor.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 10-12-2014, 05:02 PM   #12 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by johnlvs2run View Post
How did you discover all of these?
Well the primary o2 was throwing random codes all pertaining to the primary sensor. It was so messed up the computer didn't even really know what was wrong with it. On top of that, sometimes it would say I was in lean burn at 90% throttle lol. Impossible.
The back cat, I fixed the exhaust leak and the car wouldn't move under its own power, so I undid the exhaust leak and my power came right back.
Secondary o2 sensor is fine, there is just too much exhaust flow now due to no back pressure from the #2 cat because I hollowed it out. So I had to bring the o2 sensor away from the exhaust flow, spark plug anti-fouler worked perfect for this.
It was a long, gas wasting experience.
Old 10-23-2014, 04:11 AM   #13 (permalink)
2010 Insight ES-T - '10 Honda Insight ES-T
90 day: 58.04 mpg (US)
Sorry to thread hijack, but can someone tell me how to add my fuel log banner in my signature?
Old 10-23-2014, 04:26 AM   #14 (permalink)
http://ecomodder.com/forum/showthrea...ure-20941.html
Courtesy of DirtyDave, a renown scholar and gentleman, via http://ecomodder.com/forum/showthrea...tml#post449202
dmt257 (10-23-2014)
