Old 04-30-2011, 01:49 PM   #1 (permalink)
scangauge problems
So I just got my scangauge. It isnt coming on. I checked my fuses and they are all good. I used a multimeter and found that I have voltage at the connector. Any suggestions?
Old 04-30-2011, 05:50 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Have you tried both inputs (side and back) ?
Tried pushing the red-circled button ?
Did you find voltage at the car's OBD connector, or on the wire with RJ45 (network) connector leading up to the unit ?
