Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 05-21-2008, 03:50 PM   #1 (permalink)
Peakster's Avatar
Red Jeep Patriot - '07 Jeep Patriot
90 day: 25.14 mpg (US)
Beige Ford Ranger - '95 Ford Ranger XLE
Question Wind resistance while cycling.
It's a pretty windy day today which will be great biking to work with the tailwind, but real sucky when I travel home.
There are 2 ways I can get home though: one with a direct-head on wind and one with a more of a cross-wind. I'm wondering, is it less efficient to travel in a cross wind (because more surface area is being hit by the wind ) or one that's head on?
Old 05-21-2008, 04:06 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Headwind! Just a guess based on the frontal area issue, plus the fact that you'll be steering into the crosswind and adding tire scrub, increasing RR.
In the right crosswind, I pretend that I can "sail" myself forward by twisting my upper body to generate forward lift. :P
Old 05-21-2008, 04:10 PM   #3 (permalink)
Peakster's Avatar
Ha ha! Somehow that doesn't surprise me coming from you MetroMPG.
Okay, headwind it is! Thanks. Still, if someone knows the absolute answer or can link me to a site, please chime in .
Old 05-21-2008, 04:14 PM   #4 (permalink)
Pushrod - '02 Chevrolet Cavalier
Crosswind. You don't steer against it, you just lean against it a tiny bit. Much easier than riding into it. Simple vector math problem, draw it out.
Old 05-21-2008, 04:18 PM   #5 (permalink)
Peakster's Avatar
I was never good at math. Hmm, we got some conflicting advice! who do I believe now? Are you 100% sure JohnnyGrey?
Old 05-21-2008, 04:22 PM   #6 (permalink)
Head on is worse, no doubt in my mind.
Old 05-21-2008, 04:23 PM   #7 (permalink)
Peakster's Avatar
Okay, thank you
Old 05-21-2008, 04:26 PM   #8 (permalink)
Go with the majority, Peakster!
I think Johnny is closer to the right answer, because his effectively is "it depends" (TM) - on the strength & direction/vector of the wind.
Old 05-21-2008, 04:47 PM   #9 (permalink)
Yep, I'll stay with my original assessment.
Old 05-21-2008, 05:38 PM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Go where the workout is.
An Index of Cycling Links SVOboy Alternative Transportation 17 06-28-2023 12:12 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 04:24 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Virtual Wind Tunnel rockorager Aerodynamics 1 06-03-2008 05:34 PM
Bullfrog Power wind farm owner dumps his Insight for a Prius MetroMPG General Efficiency Discussion 0 12-16-2007 11:50 PM
