Old 02-06-2015, 03:48 AM   #1 (permalink)
Measuring Fuel Economy by Weighing the Car
Is this a good methodology for accurately measuring fuel economy? | TopGear.com.ph
The technical committee discussed different approaches to fuel testing. The possibility of draining the fuel systems completely both before and after the test carried the greatest potential for accuracy, but also had the potential for damaging high-pressure fuel pumps and injectors. Fuel cells were nixed as they're too expensive, and further required the partial dismantling of each vehicle's fuel system.
Then the committee turned to the applicability of weight measurement of fuel as opposed to volume. By measuring fuel consumption by weight, you eliminate the need to fill each tank completely, and any change of volume due to temperature would not affect the weight of the fuel.
Measuring the total weight of the vehicle both before and after each test also ensured that "hidden" fuel stored in the fuel rail, filter and return lines was also taken into account. Chevron/Caltex provided tables to convert kilograms of fuel into liters, based on ambient temperature.
Several further challenges were identified, but they were not viewed as insurmountable. Test runs were set at 100km to minimize rounding errors at the scales. A course was mapped out to provide a wide variety of running speeds and running conditions, and the course was marked out to ensure consistent driving and lap times. Motorsports-grade scales with an accuracy of 0.01% were sourced for these tests, and validation tests were carried out to the satisfaction of the committee.
Just wondering what everyone thinks.
The background... it was an economy test of around two dozen vehicles (only 19 showed up, but, whatevs). Previous testing had the technical crew spend two days filling the car before the test, just to make sure it was completely topped off.
Due to time constraints, this is what was done, instead.
Sounds stupid. Worked. I think. But still, a lot of questions.
Old 02-06-2015, 10:33 AM   #2 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Get a new technical committee. The way we do it here is better.
Getting to zero, filling, measuring the fill, then driving, then measuring what's left can be accurate. But every step is at best some added slop and a chance to get something wrong. At worst? A kindergartener could cheat and not get caught.
Better? Fill up, drive, then fill up again with as few variables as possible- same pump, conditions, method, etc. Measure fuel pumped on the refill.
Transmission type Efficiency
Old 02-06-2015, 05:35 PM   #3 (permalink)
You need a very precise scale and no fluid outflow from any driver or passenger. No adding of any weight during the test cycle (buy a soda or other drink-food).
Under those parameters I would prefer the weighing method.
regards
mech
IamIan (02-07-2015)
Old 02-06-2015, 08:12 PM   #4 (permalink)
90 day: 19.36 mpg (US)
Get on a Cat Scale and weigh at all four corners to be exact about tire pressures, plus correct any imbalances. Past that?
Old 02-07-2015, 03:49 AM   #5 (permalink)
Scales were motorsports grade, unfortunately, they don't read to decimal places, even though they're accurate to fractions of a pound. I suggested correcting to whole numbers using small weights, but they didn't want to take the extra step... even though I tried to explain how quick and easy it would be.
Nothing in the cabin. No water, no snacks. No AC use, so water wouldn't condense around the AC evaporator, either. If the car got lighter due to evaporation from the radiator, then that's not our problem.
The first run was done that way. We needed several fills both pre- and post- to get exact numbers. Something that would be hard to do with two dozen cars.
The method I've been most satisfied with was doing multiple fill-ups over the course of the run... then you get the median fill-up, as the first few tend to be off due to issues with the tank.
Good if you don't have a line at the pumps. Last eco-run we had, the time spent waiting for the fill-up affected the numbers... which is how two diesel crossovers got 40-50 km/l on countback... because their high pressure fuel rails took a dump back into the tank while they were sitting parked.
Personally, I would love to do this with a fuel cell. Or even a plastic bottle or bag like Mythbusters uses. I've seen a run done with a bottle mounted to the hood on a modern diesel... so it's possible, even with a high pressure fuel rail, but that requires a modified hood, so not practical to do with a lot of cars at once.
Old 02-07-2015, 09:13 AM   #6 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Trying to calculate fuel consumption by weighing the difference of the entire vehicle is terribly inaccurate. Especially if only a few gallons are used. The Green Grand Prix used to rely on this using 4 race quality scales. Some of the cars actually made fuel.
Old 02-07-2015, 07:11 PM   #7 (permalink)
Now that's interesting! And the kind of anecdotal data that would be useful to know. Have any links?
Also... What kind of run was it, and what were the parameters?
Old 02-07-2015, 07:15 PM   #8 (permalink)
sendler's Avatar
http://ecomodder.com/forum/showthrea...9-a-24524.html
The Following User Says Thank You to sendler For This Useful Post:
niky (02-08-2015)
Old 02-07-2015, 10:03 PM   #9 (permalink)
Changfa diesel + Suzuki
changzuki's Avatar
Centurion - '74 FIAT X1/9 Centurion Full Race DNA
Last 3: 143.5 mpg (US)
While I do understand the logic of weighing for fuel consumption, I agree with sendler on this one. Using last year's Green Grand Prix as an example: it did rain the night before and although I wrapped the roof in plastic, Centurion is not exactly water proof. The floors were wet, especially the rear tray where the extra cushions were mostly floating. It got worse on my side even during the trip to the event from the hotel. There's some access cutouts through the wheel wells (for door strikers and such) that allowed water in. Water in or draining out would certainly make a difference.
Maybe I'll install a couple of bilge pumps rather than fix the holes.
~CrazyJerry
Old 02-08-2015, 08:15 AM   #10 (permalink)
We avoided rain... all the cars were parked in the pit garages before the event, too.
Reading up... seems like a big issue with such small figures... 10 pounds versus 1 gallon is a pretty big level of error.
The big problem was the fuel sponsor would not allow refueling at the track... at all, which was maddening. In an ideal world, both methods would be used to audit each other.
So... I guess that leaves removing a washer nozzle, running a hose out to a bottle of fuel suction cupped to the hood, and running until the bottle is dry?
