A review of water-steam-assist technology in modern internal combustion engines
https://www.sciencedirect.com/scienc...52484721007071
Most interesting is; Inject steam from waste heat into the combustion stroke just after the std bang has done its thing at 20-25 degrees ATDC.
As in; car/engine makers think it's interesting.
Problem is buyer resistance to: "Are you saying not only do I have to fill up with gas but water too!"
ie: Paying half as much for half as much gas is considered 'more expensive'due to the 'extra trouble'.
They could put a radiator in the exhaust to condense the liter of water produced per liter of fuel burned, but that 'condenses' acids and rusts out the exhaust unless they go expensive alloys.
So it's; pay less up front and more at the gas station and no water fillup inconvenience as usual.
NB that stock, into intake, water injection DOES NOT work on a stock engine.
It works by suppressing knock when you want to send the compression ratio through the roof by head etc skimming or a turbo.
