12-19-2012, 07:22 AM
#11 (permalink)
Master Ecomadman
Hoping to get the exhaust valve today. Looks like we will get our first winter storm before it's reassembled.
- Tony
12-23-2012, 08:24 PM
#12 (permalink)
Master Ecomadman
Gaskets and exhaust valve arrived today. Not sure how I am going to check the valve seat.
- Tony
12-24-2012, 06:26 AM
#13 (permalink)
Did you not have enough cars?  Good luck!
12-26-2012, 11:21 AM
#14 (permalink)
Master Ecomadman
I decided not to mess with the old head, as the valve seat needs grinding and the adjustment requires shimming. I ordered a rebuilt head that comes with the cam shafts and valves all pre adjusted for $275 plus $20 shipping.
In for a dime, in for a dollar? Do I order new high compression 94 pistons rings and rod bearings? Will I find a Toyota engineering surprise when I try to disassemble the oil pan? OR should I just put the head back on.
http://www.scribd.com/doc/36969270/4A-FE-Cylinder-Head
- Tony
01-02-2013, 06:20 PM
#15 (permalink)
Master Ecomadman
The head finally arrived today. make me wonde4r if I sould have gotten a whole 1.5L japanese engine to swap in instead for a couple of hundred more.
- Tony
01-06-2013, 09:48 PM
#16 (permalink)
Master Ecomadman
Torqued the head down today.
- Tony
01-08-2013, 09:44 PM
#17 (permalink)
An interesting car. Never have seen one closely, ridden in one, or heard about it before now.
01-12-2013, 11:19 AM
#18 (permalink)
Master Ecomadman
Installed the cam shafts and timed it. It took a few tries as there are two sets of marks that look the same, also there is an anti-backlash device that needs to be preloaded. I'll bolt down the manifolds when I get back from the DMV. Going to licence the Honda Insight, insurance is only $74 a year more for it.
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
01-12-2013, 11:42 AM
#19 (permalink)
Do more with less
Tony
Just went to the link mentioned and it looks like they show the exhaust manifold on the same side as the intake cam.
4A-FE Cylinder Head
– Noah Webster, 1787
01-12-2013, 01:07 PM
#20 (permalink)
Master Ecomadman
Hi Dave,
The 4A-FE engine is a cross flow head, the exhaust is in front and intake behind.
- Tony
