Old 01-07-2009, 02:11 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
can i get away with 0w30 oil ?
hi
i'm thinking an oil change will help reach my mpg aspirations. it says in my haynes manual that it takes 5w40 or 10w40 oil. can i get away with using 0w30 oil ? its winter here at the moment. would an oil pressure gauge help? i take it would not be advisable to run lean with this new oil.
would a gear box oil change score me more mpg's than engine oil change? i have a manual, petrol engine.
thanks for your help
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 01-07-2009, 04:12 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I have 0 weight oil in my '93 Honda Civic with 130 something thousand miles.
I also fill it only half way between the add and full mark on my dipstick.
( My pea brain thinks that this would result in less friction for the engine. In reality, I'm probably hurting things.
Let's see how long I go before the motor dies. )
I didn't really notice any noticeable change in my mileage when I changed to zero weight, but that's my personal car. You might actually see a change.
Old 01-07-2009, 04:55 PM   #3 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
Was also curious about this, from someone that might have some technical information
Old 01-07-2009, 05:55 PM   #4 (permalink)
Fokus - '12 Ford Focus SE
90 day: 32.45 mpg (US)
Lecksus - '03 Lexus RX300
90 day: 17.61 mpg (US)
Benzzzzz - '11 Mercedes Benz ML-350 4-Matic
90 day: 18.75 mpg (US)
I think the spec for 0w-30 synthetic is ok to use in cars rated for 5w-30
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
Old 01-07-2009, 07:03 PM   #5 (permalink)
on the back of the 0w30 oil can it says "for most modern engines." my engine is only 9 years old so i think its cool no?
Old 01-08-2009, 01:14 AM   #6 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Making the jump from "10W40 or 5W40" to 0W30 is a bit stretchier than say getting 0W40, which would be (I think) fine. If it exists.
Old 01-08-2009, 11:18 AM   #7 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
I assume your car isn't making alot of hp? Do you lug the engine for mileage?(3/4 throttle or more at 1800 rpm for example) Is the motor in good shape? not burning oil, or has any bad ticks or clanks, high mileage? Do you tow anything?
If all no, then you should be fine running almost any oil, but in your climate it makes more sense to use 10W30 to me, in general the closer the numbers the longer the oil lasts close to the original specs.
Switching both the engine and tranny fluid to synthetic should result in small increase in mpg as well. Without closely tracking mileage you probably won't notice.
Ian
Old 01-08-2009, 12:08 PM   #8 (permalink)
DMC - '99 Honda Civic DX
Older engines require thicker oil due to bigger tolerances between the parts. Filling up really thin oil might cause some leaks. Modern engines have smaller tolerances due to technology bein advanced where the engine parts have smaller gaps between each other.
Old 01-08-2009, 12:35 PM   #9 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
if you really want to know what is going on then install an oil pressure gauge, with the larger gaps in an older engine an oil that is to thin will flow out of the bearings to fast and leave them dry, if you can keep enough oil pressure with thin oil then you are good.
Old 01-08-2009, 05:08 PM   #10 (permalink)
Cd
Ultimate Fail
Cd's Avatar
What are the signs of bearing damage ?
I would hate to think I did something STEWPED like damage my bearings .
Also, can having the oil in the car at below 'full' ( mid way between add and full ) be a stupid thing ?
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Alberta Oil Sands Gone4 The Lounge 8 02-19-2008 07:58 PM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
Oil weight question: 0w30 or 5w20? MetroMPG EcoModding Central 4 11-25-2007 08:57 PM
