12-30-2014, 11:07 AM
#21 (permalink)
Since this is more of a fact gathering thread, I will say that I have use Lucas Oil fuel system treatment with success. My Intrepid was beginning to take longer to start than normal and I deduced that it must be from not building fuel pressure fast enough.
Within 50 miles of adding it to the tank fuel pressure was back to normal and it would fire on the 2nd revolution reliably again without hilding the key on before starting.
Additional lubricants in the fuel, especially for cars with higher mileage, is helpful.
12-30-2014, 10:17 PM
#22 (permalink)
Aero Deshi
I should start using the 2 for 1 Lucas oil deal I got a few years back. I think I put it in my Honda once.
It was a bargin......you know....something you don't need at a price you can't pass up!
01-01-2015, 09:56 PM
#23 (permalink)
Intermediate EcoDriver
I tried Chevron Techron fuel system cleaner in my Mustang once. It didn't make any difference in fuel economy, but it only cost $7.99 for a 12-ounce bottle.... $85.23/gallon!
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
The Following User Says Thank You to Mustang Dave For This Useful Post:
05-09-2015, 02:11 PM
#24 (permalink)
I think the unicornism is in the lack of data regarding the ATF.
A lot of the stuff you put in the tank (other than gasoline or diesel respectively) you only hear people saying that "it definitely works for sure" but real numbers are missing.
As a side note, I'm not so sure a cat or dpf doesn't suffer from those additives and especially atf. Heck, even using the wrong oil grade can have a detrimental effect on a dpf.
05-13-2015, 11:10 AM
#25 (permalink)
I saw the link on Page 2, which downloaded a PDF to my computer. I'm a member over at the same forum (DieselPlace) and the test results are posted on there in a thread too.
In short, the results of all that was tested or listed in the test results (if you're not a member there and don't want to register...) showed that 2% Biodiesel was the one that lubricated the most. Personally, I'd like to just fuel up with B5 (5% Biodiesel) but if I can't get that then I'll have to go get 100% and mix it in with ULSD.
Note: Some Diesel engines can't take 100% Biodiesel without some modifications to the engine so don't just fuel up with 100% if your engine can't handle it. I realize there are people here who know that, I'm just posting it for anyone who doesn't.
05-15-2015, 06:49 PM
#26 (permalink)
The PRC.
Isn't Diesel a lubricant anyway ?
05-15-2015, 07:57 PM
#27 (permalink)
Not banned yet
getto - '02 Volkswagen Jetta GLS TDI 90 day: 53.82 mpg (US)
sulfur lubricates as lead did. correct me if i'm wrong.
FOR SALE: 02 TDI Jetta- 5 sp: Cooper CS5 at 50 psi, UltraGauge, ventectomy, rear air shocks, mufflerectomy, LED plate light, upper fiberglass grille block, front lower pan, front fairing.
93 Chevy CrewCab 6.5 TurboDiesel, GearVendor OverDrive, 4L80 w/ TCI controls. Now DailyDriver
05-16-2015, 05:21 AM
#28 (permalink)
The PRC.
Probably. Just relating it to something I read years ago about mis fuelling.
05-16-2015, 07:06 AM
#29 (permalink)
A few of the newer ats (atf+4 for dodge) is synthetic dusn't change color when you get it hot or old asper Dodge so imo avoid synthetic atf
as for 2 stroke synthetic. I won't run it in my 372xp chainsaw because of ash fawling and buld up.
old 2stroke didn't burn up= smoke and oil fawling
for a gasser more oil=less fule aka leaner to much oil can melt pistons
As for lack of testing what is the life expectancy for a injection pump 200,000 500,000 1,000, 000 mijust how many more miles duse atf give ? I have275000 on a vp44 using ctane booster 1floz for 3 gal skip it for 2 tanks and that old 12v starts talking clattering, hard starting
[Quote] will it hert my ??? Parts [quote]
if gas , then zinc is fatal for your cat .it was taken out of motor oil To be able to give an epa mandated 100,000mile wornty .It was a friction modfier its removal required the change to roller-cams.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
05-16-2015, 12:50 PM
#30 (permalink)
There are those who use WalMart TC3 2-stroke oil in HPCR engines. A small amount. I've tried it and saw no FE improvement. So that is not the reason to use it, but fir supposed lubricity improvement.
I use Power Service pretty much all the time. And buy Shell of Exxon diesel. The combo is worth close to 1-mpg highway versus straight diesel.
And it's Unicorn as there are not genuine studies advocating this. In the days of mechanical, low pressure diesels one could burn oils fairly easily while on the highway and under a load.
Today, there's no smarts in threatening expensive injectors. About $4000 with installation and associated part replace by for six on my Cummins.
