View Poll Results: Should the car idle reduction modification go into the proven section?
Push mod up to proven section 10 100.00%
Pull mod down to hoax section 0 0%
Voters: 10. You may not vote on this poll
Old 01-17-2013, 06:47 PM   #11 (permalink)
Smile
I finally was willing to back off of the mod long enough to get before and after pictures of my scangauge. I was able to measure a drop from .42 gallons per hour at 550 rpm to .38 gph at just under 500 rpm. This is an improvement of about 10%. I accomplished this mod by adjusting tables within the ECU/PCM with a handheld programmer.
ID:	12271   Click image for larger version
The Following User Says Thank You to wriley4409 For This Useful Post:
Piwoslaw (02-01-2013)
Old 02-01-2013, 03:09 PM   #12 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
^^ When you did the test, was everything else the same? For example coolant temperature, electrical load, etc.
Old 02-01-2013, 03:48 PM   #13 (permalink)
I did the testing back to back with only a few minutes needed for the PCM update, so everything was reasonably similar if not identical. All electrical loads were identical between tests, and I allowed the idle to settle in before snapping the pictures of my Scangauge.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
