Old 03-29-2009, 01:13 AM   #1 (permalink)
JackMcCornack's Avatar
Motorcycle carbs on a Metro?
I'm interested in putting bike carbs (horizontal draft) on a three cylinder 996cc Metro/Sprint/Etc three cylinder engine. Anybody got ideas for me? Or even better, experience?
It's going in a Lotus Seven look-alike, it'll be a gasoline version of my Kubota diesel car (MAX), working title MAXine. Any clues will be appreciated.
Old 03-29-2009, 01:49 AM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
well, your metro engine is going to be turning alot slower, so carbs from a smaller engine should work, but then you are going to need new jets to make up for the change in air velocity, I don't have a copy of any intake and exhaust books in front of me any more but there are definent formulas to make this work, another option would be to get multi throttle bodies, there are a number of motorcycles that have fuel injection like that.
Old 03-29-2009, 02:42 AM   #3 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
A few people on teamswift have done the motorcycle carb conversion. It is pretty much only good for racing and top end power. If you are interested searching around on that site will give you some ideas on what is involved in doing it.
I don't think it would be easy to do but maybe drilling out the injector ports in the head and just adding 3 throttle bodies from a bike would work out good. With a setup like that you also would need to run a Megasquirt computer and a huge amount of custom tuning work. If you are really wanting to push the power and rpm limits on a 3 cyl engine it is probably a good setup to use. For economy it won't get you much if anything.
Old 03-30-2009, 12:27 AM   #4 (permalink)
It's a Metro engine, but it's not in a Metro. The carbs are an interim proof-of-concept step, the objective of side draft in this application is to reduce frontal area...I know this is a bit over the top, but it's a very small car and I believe it will help overall vehicle efficiency even though it won't help engine efficiency. Team Swift has lots of info on bike carbs on the DOHC 1300cc bangers, and yes they do seem to get more power, but for me it's a space issue rather than a muscle issue.
I was hoping somebody had done it allready, and could tell me that Hodaka Ace 90 carbs are just the ticket, or a set of Amals from a 1932 Henway or something...
Old 03-30-2009, 12:47 PM   #5 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
I believe the Hodaka Ace was a two stroke, if so the carbs will not tune correctly because the slides are shaped differently than four stroke slides. I wouldn't touch Amals when Keihen carbs from many four cylinder hondas are in abundance. I would try to get a set of mechanical (not vacuum) carbs off an early '70's Honda CB-750. There is a good aftermarket for them, you can get the adapter boots with them, they will not be too big, and they will be very easy to tune. I'd favor an undersize carb because it will help your low end responce, giving a better vacuum signal over the venturi so it will be easy to tune. Also, if you use those Honda carbs, you can use the throttle cables right off of it to make sinc'ing a cinch.
Just my two cents...
Electric Motorcycle conversion bennelson Fossil Fuel Free 315 01-27-2018 03:51 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Anyone see this 3 wheeled Metro? Johnny Mullet EcoModding Central 46 12-20-2008 08:28 AM
Extreme Electric Motorcycle conversion for Publicity/Charity - in Motorcycle forum! bennelson Fossil Fuel Free 0 11-17-2008 06:07 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 07:26 PM
