Old 05-30-2009, 07:28 PM   #1 (permalink)
blueflame's Avatar
Mountains, gliding and wearing out brake rotors and drums
Had 2 new front tyres fitted which increased FE and comfort. Damn those old tyres!
However, the tyre guy showed me considerable wear which has occured on the front disks since I have been EOC down a mountain range almost every day for the last 6 months.
Now I'm gonna be engine braking a lot more when it comes to large downhills....
Incorrect hypermiling just cost me a lot of time and money!
The front disk rotors may need replacing soon.
Grrrr
Old 05-30-2009, 07:31 PM   #2 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
I used to always use engine braking, until someone mentioned the relative ease of doing brakes vs clutch work.
Old 05-30-2009, 07:45 PM   #3 (permalink)
Engine braking doesn't wear the clutch.
Old 05-30-2009, 07:53 PM   #4 (permalink)
it isn't the braking per se, it is shifting into those lower gears, especially with a conservative blip on the gas.
Old 05-31-2009, 06:25 PM   #5 (permalink)
Tartaruga - '09 Fiat Palio
Last 3: 23.7 mpg (US)
you may reduce clutch wear by revving up the engine while releasing the clutch. Since there is no load and its used only to match rpms the fuel comsumption is minimal and probably will cost you less than clutch wear and much less than brake wear... Also if your car cuts fuel when you are geared but not accelerating, its now wise to EOC and use brakes.
Old 05-31-2009, 09:31 PM   #6 (permalink)
Hi,
If you can downshift and use the engine to brake, then you use the same amount of fuel as EOC'ing and you get to not use the brakes. Best of both...
Old 05-31-2009, 09:46 PM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
If blessed with mountains, I would turn off my injectors and engine brake (hold in the kill switch).
For reference, I did the rotors today, they were $18 apiece, but would still rather use the engine to control my decent and save the brakes for an emergency.
Old 06-02-2009, 06:31 PM   #8 (permalink)
blueflame's Avatar
Citroen AX rotors are much harder to find, 3 were crushed and melted recently and I should have grabbed a pair as there are none around here at the moment. Except for my complete and running other 2 AX's, maybe I should wreck/break/part one of them, probably worth more that way anyway, AND I have my rotors right here
Being carburetted I use gas when engine braking, ignition on or off.
Over the last 6 months hardly more than a couple of dollars gas MAXIMUM would have been used, during needed engine braking.
Better than worn rotors. I was penny pinching and look what happened.
Old 06-05-2009, 09:32 PM   #9 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
I am carbed, but do not notice gas, it would rather the pcv and suck on the engine base in a round about feed. In a way this is good, but the reason for good is too rare to keep it that way. Fuel injection has a thing called "air bypass" when engine braking, it is supposed to just let air in and not the fuel. I was just pondering using the uselss egr valve filtered to open air and let the high vacuum of letting off throttle open it..work like a charm and get it past the carbs venturi, carb would think it was idling
As myfuel is already in the hyper realm, this bypass would make it for anyone to keep acheiving. I know what engine brakes do to natural venturi, alot don't. the king of fuel air and its simple problems...
Old 06-07-2009, 10:15 AM   #10 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I would suspect that with the carb, having the throttle closed would reduce the amount of air coming in quite a bit, and so you wouldn't be using the same amount of fuel per rpm as you would if you were powering it to that rpm. The throttle plate is after the venturi, right?
Also, I wonder if you have an electric fuel pump, or the more likely manual fuel pump. If you were lucky enough to have the electric fuel pump, a on off switch for the pump would be nice; you'd only lose the gas in the carb's bowl, and refilling it wouldn't take but a second. But I suspect you'd have a manual fuel pump, which makes it a bit trickier...
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
