Old 09-22-2008, 12:41 PM   #1 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
Question --- MPG Gain With Engine off at Stoplights? ---
I Am not talking about EOC, since i have an automatic, just turning off the engine at stop lights instead of leaving it idling...
Anyone has any mpg gains by doing this? ...I am trying to see if it really is worth it; If i gain only 1mpg I wount go through the trouble but if its something like 3-4mpg then of course...
Old 09-22-2008, 12:52 PM   #2 (permalink)
Truck Nut
Blue BAT - '06 Toyota Tundra Double Cab
90 day: 16.28 mpg (US)
Driving patterns.
Depends a lot on your driving patterns and how much fuel you burn just sitting there at idle. The Blue BAT burns 0.6 gallons per hour stopped, idle, in gear. I can end up spending 15 minutes waiting at lights in a 20 mile urban drive. Let's say I get 20 mpg while in motion. I would burn 1.15 gallons with engine on at lights or 1 gallon with engine off. That is the difference between 20 mpg and 17.4 mpg.
Truck Nut
Old 09-22-2008, 01:00 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Actually I just tested this. Idling at stops was %17 of my fuel in the test. Every car/driver/route will be different of course, so I added tracking of fuel spent at 0mph to the guino:
http://ecomodder.com/forum/showthrea...ting-5144.html
Old 09-22-2008, 01:05 PM   #4 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
In typical city driving, you use at least 10%-15% of your fuel idling. I read a research paper that quoted a city EPA figure of 17%, though the exact driving cycle was not specified (see zero inertia powertrain)
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 09-22-2008, 04:23 PM   #5 (permalink)
Kawi - '04 Kawasaki Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Chevrolet Monte Carlo Z34
90 day: 26.52 mpg (US)
Mazda - '10 Mazda 3i
90 day: 35.15 mpg (US)
Turning the engine off at lights, especially ones you know are long is certainly worth it if you tend to do a lot of urban/city driving. You can EonC in an automatic, I do it all the time with my Monte Carlo. It helps if the gear shift is on the floor, but you can still do it if it's on the steering column. Simply shift into neutral (if the gear shift is on the floor you can go between neutral and drive without pushing the button. Coast up to the stop and with the brake applied just shift back into drive. You can usually shift into drive without the brake, but this depends on each individual vehicle.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 09-22-2008, 04:30 PM   #6 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
I don't know about gaining, but I watch my "current" MPG drop off while I am idling. I suppose that any time you are not moving and not using gas, that would be an MPG gain, vice idling and not moving.
The rest of your question - I lose about 1/2 mpg max idling over 30 seconds - depending on how far I have traveled on that trip. The less time it has been since I started the trip the more MPG loss.
Old 09-22-2008, 04:43 PM   #7 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
On a typical drive in my town, I've measured about a 15% difference.
Old 09-23-2008, 07:02 PM   #8 (permalink)
off on
July 1980 Popular Science,page 70:"Stop-go fuel saver",by Zemco Corp.,San Ramon,California.Tested on EPA Urban Cycle,the device(which does as you describe) improves mpg by 7.5%.
Old 09-23-2008, 07:46 PM   #9 (permalink)
ptsmith24's Avatar
El Camrino - '90 Toyota Camry LE
90 day: 32.47 mpg (US)
Once I get my MPGuino calibrated, I'll test how much fuel I use idling and try to remember to post back.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Old 09-23-2008, 08:55 PM   #10 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
One thing I wonder about shutting the engine off is... does the computer go into open loop or does it run a little rich on startup? Or is that only on a cold start.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
MPG Gain -- Time to pay off Noel General Efficiency Discussion 3 08-14-2008 06:00 PM
New York mechanic Andyman Introductions 6 05-13-2008 12:02 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Estimate of mpg gain? EcoJeeper EcoModding Central 4 01-23-2008 07:59 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
