Old 05-19-2011, 06:27 PM   #1 (permalink)
wyatta4's Avatar
CRX:HF - '89 Honda CRX HF
90 day: 53.05 mpg (US)
NameGoesHere - '15 Volkswagen Golf TDI SEL
MPG on laptop
Has anyone heard of hooking their laptop up to there cars?? I want to hook one up to a CRX so it displays such as a scangauge or MPGuino.. I will be converting te electronics to OBD1 when I swap the VX motor into the CRX
Check out my project here---> 1989 CRX HF
Follow me on Twitter. @secsieAzul
Old 05-19-2011, 06:28 PM   #2 (permalink)
wyatta4's Avatar
The swap won't be for a while, however.
Old 05-20-2011, 01:42 AM   #3 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
I did, but with an obdII. What I use is called OBDwiz, cost about $40ish. It is a little cumbersome to use the laptop though, and I wouldn't advise doing it solo unless you are logging and look at it later.
Old 05-20-2011, 08:02 AM   #4 (permalink)
wyatta4's Avatar
So that's not going to work for me right? Cause I'll only have OBD1...
Old 05-20-2011, 08:21 AM   #5 (permalink)
wyatta4's Avatar
I'm guessing MPGuino is going to be my only option? Can I plug the MPGuino into my computer for charts and such??... Thanks
Old 05-20-2011, 10:58 AM   #6 (permalink)
The PRC.
There are some cables which comvert OBD1 to OBD2 and also link to a PC via USB.
I have no idea about software though, it is something I have thought about to run with my in car camera. The idea would be to log some SG2 type data such as MPG etc. and have a split screen display showing instruments at the bottom and the view outside at the top.
