Old 06-01-2008, 03:52 PM   #1 (permalink)
Some Guy
Frankenstipe's Avatar
2007 Toyota Corolla S - '07 Toyota Corolla S
90 day: 29.56 mpg (US)
Hachi-Roku - '87 Acura Integra LS
PSI question
I'm taking a 330 mile trip tomorrow and have a lot of stuff packed into the trunk and some in the back seat. I've heard you're supposed to inflate your rear tires more to accommodate for the added weight. I was already planning on pumping up my tires to 40 psi from 32 psi, so my question is how much more should I pump them up in the rear? Should I pump them above 40 psi, or would 40 psi all around be enough to take car of that extra weight?
I may be crazy but at least I'm not sane.
http://www.cardomain.com/ride/3008712
Old 06-01-2008, 03:55 PM   #2 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Do you know what the extra weight is?
The difference between extra weight - 2 bags and an umbrella & a trunk loaded with concrete blocks is significantly different. See if you can calculate the extra weight and I am sure one of the gurus here will give you a better answer.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 06-01-2008, 06:33 PM   #3 (permalink)
Some Guy
The total weight added is just shy of 200 lbs, the max sidewall PSI is 51, but it also says not to inflate beyond 40, so I'm a little confused as to which it is. I'm looking to inflate it to account for the added weight but also to evenly distribute it so as to not decrease handling by a big amount, while also gaining some MPG.
Old 06-01-2008, 07:54 PM   #4 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
If it were me, I'd go with max sidewall. I haven't seen any study that proves you would be at a greater risk running max sidewall pressure.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 06-01-2008, 08:07 PM   #5 (permalink)
Some Guy
I'm afraid of doing that really, for normal cruising I don't see much of a problem but on roads that are very windy, twisty and sharp your tires are all you have to keep you from losing traction/grip and crashing. Not to mention the random objects like rocks lying in the middle of the road around a sharp corner that are unavoidable.
45 is the highest I'd go personally but I'm starting out at 40. I just want to know if the rear tires need to be inflated more than 40 to account for the extra 200 lbs of weight in the trunk.
Old 06-01-2008, 08:47 PM   #6 (permalink)
90 day: 51.82 mpg (US)
I wouldn't lose sleep over adjusting pressure for 200 lbs extra. (EG: Do you normally inflate your tires more when you take rear seat passengers?)
Old 06-01-2008, 09:02 PM   #7 (permalink)
Some Guy
LOL good point, I guess I was just worried because the back suspension is pretty hunkered down with all that weight. The tires look fine, not like they're going flat or anything, just figured with all that extra weight might need to up the PSI.
Old 06-05-2008, 11:54 AM   #8 (permalink)
gamer_jim's Avatar
Reds' Bucket Mobile - '01 Chevrolet Cavalier 4 Door Sedan
90 day: 33.46 mpg (US)
I guess that depends on the size of the passengers?
Old 06-05-2008, 04:04 PM   #9 (permalink)
Some Guy
I got a little scared so I took Highway 20 instead, I'm more familiar with it and my sister was in the car with me so I didn't want to freak her out. I averaged about 40 MPG over 8 gallons, not bad but I was hoping more considering I pumped up the tires 20 PSI above door specs. I'm going to do one or two tanks of city driving with my tires this high just to see if it helps city MPG any. If it's not worth it I'm going to go back down to 32ish, center tread is bulging out noticeably and that's going to wear it hella fast.
Old 06-06-2008, 07:05 AM   #10 (permalink)
Frankenstipe, what you see on the tire is not necessarily what is happening at the contact patch. Have you checked it? Lift the car, apply some water base paint on the tread so it's easy to clean, lower the car on a sheet of paper and lift again to look at the result and see if the whole width of the tread made contact.
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
A Question LostCause The Lounge 5 04-06-2009 11:01 PM
Scanguage users - accuracy question Formula413 Instrumentation 7 08-26-2008 04:55 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
newb intro and question about civic hb vx reformed Introductions 9 01-29-2008 11:28 PM
