Old 01-03-2014, 01:43 PM   #1 (permalink)
Black sheep 2013 - '11 Volkswagen Jetta S
90 day: 29.01 mpg (US)
black sheep 2014 - '11 volkswagen jetta trendline plus
90 day: 29.78 mpg (US)
Black sheep 2015 - '11 Vw Jetta mk6
90 day: 22.42 mpg (US)
vacume guage & scanguage question
excuse my ignorance im new to combustion engines, i want to install a vaccume guage so i can monitor my engine closer and so i can accelerate at the most efficient rate, if i set my scanguage to MAP will this give me the same kind of readings the vaccume guage will give me? thanks !!!
Old 01-03-2014, 01:57 PM   #2 (permalink)
Yep.
Most cars can give you an actual load as a percentage of power, its LOD on the SG, dunno about the UG.
Old 01-03-2014, 01:58 PM   #3 (permalink)
are LOD and MAP close to the same thing ?
Old 01-03-2014, 02:17 PM   #4 (permalink)
It depends on the ECU programming. Some engines give you actual engine load as a percentage of power currently available. Some report the load of the engine versus maximum power output. I think most are the former.
