Old 03-15-2010, 09:40 PM   #11 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
I actually had replaced a computer power supply previously, so I had a pair of the floppy connectors and wiring available. I did have to refer to the picture above (thanks DCB) in order to confirm I connected things right.
One issue. It seems when I initially went wire hunting, I accidently connected the VSS ground wire to the MPGuino instead of the VSS output. I could not figure out why it would not work right at first. Have I done permanent damage? I have connected the correct wire now, but wanted to check and see if something needs to be replaced before I proceed...
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
MPGuino rebooting and freezing also... Power issue? tygertec OpenGauge / MPGuino FE computer 28 04-17-2011 04:05 PM
Super MPGuino? gtkid2002 OpenGauge / MPGuino FE computer 97 02-06-2011 12:39 PM
Scanguage vs MPGuino - 96 Prizm justjohn Instrumentation 16 02-18-2010 02:39 PM
All default values for MPGuino? JohnNeiferd OpenGauge / MPGuino FE computer 2 09-16-2009 12:24 PM
