Old 11-08-2013, 08:55 PM   #1 (permalink)
Need help...
I went and filled up the tank on my metro that I haven't used since spring.
When I went to reset the mpguino, I went into setup instead. Needless to say I screwed up the settings and it doesn't read right anymore. Can someone tell me if these settings are right or wrong. My mpguino was built by dcb.
Here are the settings.
Contrast - 0000000056
VSS Pulses/Mile - 0000008208
MicroSec/Gallon - 0500000000
Pulses/2revs - 0000000003
Timeout - 0420000000
TankGal - 0000010301
Injector Delay uS - 0000000500
Weight - 0000001650
Scratchpad (odo?) - 0000000000
VSS Delay ms - 0000000000
InjTrg - 0000000001
Metric - 0000000000
Instant and tank readings are way,way off.
I used the wiki to try and reset the values. However some values are not covered very well.
Any help would be appreciated.
Old 11-08-2013, 09:01 PM   #2 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
"InjTrg" is used by MPGuino to determine whether your fuel injector has a switched ground (most cars) or a switched power lead (Audis, maybe others). Normally, "InjTrg" should have a value of 0. If it's 1, you will likely see strange behavior (like fuel usage rate being larger at idle than when you're driving down the road).
Also, "VSS Delay ms" might should be 1 instead of 0. IIRC, Geo Metros used a mechanical VSS pulse generator, that required debouncing.
The Following User Says Thank You to t vago For This Useful Post:
redneck (11-08-2013)
Old 11-08-2013, 09:38 PM   #3 (permalink)
Thanks...
That was it. Went out and took it for a little spin and all was good.
Next time I will be a little more careful when pushing those buttons.
