Old 07-03-2008, 09:29 PM   #1 (permalink)
A Few MPGuino Questions
I'd like to build one. These questions are probably all answered somewhere, but there is a lot of material to sift through in here.
1. The thread with instructions calls it "build one", so I just wanted to be clear. Are those instructions ready to go?
2. The link for a Freeduino is out of stock and they recommend a 2.0 kit. If I buy that instead, are all the other instructions the same? Or do they need to be adapted to the new board?
3. I'm completely unfamiliar with duino. How will I copy and paste the program from the internet into the board? Does it connect to my computer with USB or something?
4. Am I going to find the other parts (2 5.1v zener diodes, 1 2n3906 PNP Transistor, 1 220 ohm resistor, 2 100k resistors, 3 tactile switches) at any decent Radio Shack?
Old 07-03-2008, 09:33 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
1. Yep
2. Not sure, I used an iduino
3. USB or Serial, you use a program called arduino 11
4. Yep
Old 07-03-2008, 10:06 PM   #3 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Could someone please link to the thread? Im in the same boat, Id really love to build one since all my cars are OBDI but Im totally lost when it comes to fancy electronics and flashing chips. I can solder pretty well and can do relay logic, but thats about it. I have done quite a bit of programming on a TI85 calculator, and lisp programming for Autocad, but this is probably quite a bit different. And Ive never flashed a chip before. I learn fast though.
Winter daily driver, parked most days right now
Summer daily driver
Old 07-03-2008, 10:08 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
http://ecomodder.com/forum/showthrea...pace-2115.html
With the iduino all you need to do is open the code in arduino 11 and hit upload, no big deal,
Old 07-04-2008, 05:04 PM   #5 (permalink)
Bun - '02 Ford Focus ZTS
90 day: 31.3 mpg (US)
The freeduino 2.0 works great.
I bought one of each version because the 2.0 is said to upload more reliably.
Old 07-05-2008, 10:47 PM   #6 (permalink)
Arrow
And all of the work is exactly the same just as if the 2.0 that I'll buy was a 1.0?
Old 07-14-2008, 04:36 PM   #7 (permalink)
Another Question
What wattage do I want on the resistors?
Old 07-14-2008, 05:19 PM   #8 (permalink)
4OVER4 - '85 Mitsubishi Starion ESi
90 day: 24.97 mpg (US)
Auto - '87 Mitsubishi Starion LE
90 day: 23.65 mpg (US)
Soarer - '96 Lexus SC-300
90 day: 25.27 mpg (US)
I'm using 1/8w
Old 07-23-2008, 05:28 AM   #9 (permalink)
Is anyone using a different computer than the one called for in the DIY page? The one in the link AND the 2.0 that replaces it are unavailable.
Old 07-23-2008, 09:20 AM   #10 (permalink)
Here's what I'm using:
Freeduino Arduino Diecimila compatible board complete KIT
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
Questions about mpguino mhmitszach OpenGauge / MPGuino FE computer 37 07-01-2008 07:38 AM
Just a couple of questions... 97Cavalier General Efficiency Discussion 2 06-05-2008 10:31 AM
Misc pumping losses questions tasdrouille General Efficiency Discussion 11 03-27-2008 08:14 PM
