Originally Posted by Occasionally6
Do you mean in the trans. or in the torque convertor?
There is a stator and associated one way clutch in the torque convertor that is used to redirect the fluid velocity from the drive to the driven side of the TC, thus improving the efficiency of the drive across a range of speed difference between the engine and the trans. input shaft. The presence or absence of the stator defines the difference between a simple fluid coupling and a torque convertor.
There is also, almost universally these days, a lock up function where hydraulic pressure is use to clamp a clutch (Torque Convertor Clutch) inside the convertor and provide direct drive when slip is undesirable.
I suspect that what is happening is the TCC is being locked up creating a solid connection between the engine and trans. such as would be the case with a manual trans.. It might be educational to coast down to a speed at which the TCC disengages and feel the drag of the engine go away as the TCC is allowed to slip again.
I do mean in the transmission, not in the converter. There is also a sprag for the torque converter stator. The torque converter, even backwards doesn't slip very much, say 10% or so. GM transmissions are big on this arrangement, TH350s, TH400s, 700R4/4L60Es, 4T60E's, 4T80E's, among others all freewheel nicely. You can watch the tach drop when you let off the gas and the thing will just coast like it's in neutral. It's nice sometimes, little hard on brakes in the mountains for your average driver though.
As per Wikipedia (which is of course always accurate)
"A sprag clutch is used in most older automatic transmissions and some newer ones for shifts which require the synchronized engagement of one clutch with the disengagement of another. Using an overrunning clutch instead of a hydraulically actuated one makes this synchronization automatic. The sprag clutch simply "lets go" once the reaction force it provides is no longer needed. In a Simpson gearset, common to many automatics, this happens on the 1-2 shift, and reverses on the 2-1 downshift. The 2-3 shift is done by engaging a single clutch, and nothing is released. Some newer electronically controlled transmissions make "clutch to clutch" shifts, without any sprags.
This can also be used exclusively in first gear (transmission shift lever in D, but auto valve body or management selecting 1st) on some autos. That way it will automatically provide forward drive, but will not provide any engine braking. This is done not so much to avoid engine braking per se, but rather to allow a low throttle opening 2-1 downshift as a car decelerates, to avoid a loud (and potentially abrupt) and unnerving jolt as a result of the downshift. On transmissions so equipped, manual selection of 1st gear typically engages an additional band that grips the same section as the one way clutch would engage, and thus allows for engine braking."
One of the original selling points of the "Hondamatic" transmissions was their strong engine braking. They are meant to do it, torque converter lockup or no.
