Old 01-07-2009, 07:23 PM   #1 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
Turtle --- My New Metal Rear Underbody Diffuser ---
So, I just finished 15 minutes ago, with a cut finger
Made of 30 gauge sheet metal (Would have probably done 26 gauge if I were to do it again), the total cost was of $35.12. The sides are flush with the tire (actually, a little more "inwards"), the pictures make it show in some angles as it would be extruding past the tire and rim, but it does not.
I painted the top and sides black (with spray paint, and two coats of clear) so that it would look a little more like all those exotic cars carbon diffusers ... Ok I tried I tried ...
I still have to do the middle, but that will be tomorrow as its dark now. But I am VERY happy with the results so far. It is going to be FAR superior to the little dinky things of coroplast that I had on there before. Haven't gone on the freeway yet but the rivets should hold everything in place and everything should be good to go.
(Pictures are from phone, sorry!)
Old 01-07-2009, 07:27 PM   #2 (permalink)
Lil Sulf - '94 Toyota Corolla
90 day: 47.62 mpg (US)
Wow, you car looks......normal.
Nothing like my rear-wheel-skirted, grille-blocked, side-mirror-deleted coroplast-gorillatape car.
And that's without a Scangauge o.O
Old 01-07-2009, 07:36 PM   #3 (permalink)
That's my number one objective with this car; yet it has a grill block, front tire deflectors, front underbody diffuser, vortex generators, ALL LED lights, etc etc etc.
I want for people to think green in a way that many don't, which is that any car can be "green" while being "normal" or good and sporty looking
Old 01-07-2009, 08:40 PM   #4 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
I like it. I'm in Sulfuric's camp: Coroplast and Gorilla tape. But my wife wants nothing to do with appearance-altering mods. You present a good compromise!
Do you have a Scangauge to verify results?
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 01-09-2009, 11:23 PM   #5 (permalink)
Looks like you should pull in the sides
Old 01-10-2009, 05:44 AM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
basslover911 -
I think winkosmosis is right, but I still like it. It makes me think of the Prius.
CarloSW2
American Solar Energy Society
Old 01-10-2009, 01:23 PM   #7 (permalink)
diffuser
What is it's angle with respect to the ground? And do you have a bellypan leading up to it?
Old 01-10-2009, 07:17 PM   #8 (permalink)
The ones behind the tires (the ones on the pictures) are not steep at all, probably around 3 degrees.
The middle one (which is finished now) is more like 7 degrees or so.
Also, I don't have a complete belly pan yet (I have the oem one in front but nothing in the middle of the car yet). I am going to see how durable this diffuser is and if everything works good I will make the middle one in about two months or so (Since that one is bigger and is going to be a little more, probably around $40 or so).
Old 01-10-2009, 07:19 PM   #9 (permalink)
In regard to the sides, I wanted them as close to the edge of the tire as possible as to catch all the air coming out of the spokes of the wheel and try to straighten it out a little before going into the wake.
Old 01-10-2009, 07:28 PM   #10 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Nice !
Functional, yet 'cool' to the uninitiated. 'thumbsup'
I'm a little concerened about pedestrians and children. If they brush up next to your car, will they get cut ?
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 130 02-10-2015 08:50 PM
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
rear diffuser fabrio. Aerodynamics 30 05-17-2010 12:36 AM
Window trim hurting aerodynamics? And a solution for my rear doors. Sean T. Aerodynamics 36 10-19-2008 07:58 PM
tigra AERO PROJECT rear end question fabrio. Aerodynamics 19 03-31-2008 12:01 PM
