Old 02-23-2009, 01:42 PM   #21 (permalink)
a$$ pirate - '97 Ford Aspire
Metro:
Thanks for that post, i was having a little trouble finding exactly which one Aerohead was talking about. I am Curious why the 0.16 one has more of a bluff back, and the more boat tailed is a 0.18.
Malibu:
Your van is sweet, way less soccermomish than mine. Jealous.
Daox:
You are dead on man, wheels have two planar surfaces purpendicular to your flow direction, and the rim is usually an effective fan. I would say of any one thing on your car, Wheels might have the highest Cd. Case in point, solar powered racers have rounded tires, like a Road bike, or an old timey airplain, they are not radials like on a car, sure they loose some traction, but get a way better Cd, and lower RR. I have thought long and hard about what you could do to reduce this effect, there isn't a whole lot, besides airdams and sideskirts.
Old 02-23-2009, 01:46 PM   #22 (permalink)
Tonight I am finnally going to Finish my Kammback, and work on remounting my internal mirrors, the Blue tape is cool and all, but it is time for a more permanent solution. I'll post pictures when I get all that done. Next I want to Belly pan, I am also thinking of extending my belly pan behind the rear bumper a bit, to help soften the flow seperation behind my sweet Ride.
Old 02-23-2009, 04:54 PM   #23 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
hey bteck...thanks, that van was a ton of fun & i learned alot from that van, i hope to get another '94 or '95 & come back swinging & taking names :P
them 41te tranny's are sensitive to heat, make sure to have a cooler for it & what little airflow your allowing in, make sure goes thru it, i think most of the 4th gen vans have factory coolers now, but i may be wrong
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 02-23-2009, 07:33 PM   #24 (permalink)
wheels
Looks like we need to come up with a mod to delete wheels!
Is Luke Skywalker lurking out there? He'd be the one to consult.
Old 02-23-2009, 11:11 PM   #25 (permalink)
Malibu:
Thanks for the warning about the tranny, I didn't know that, Mine is a 2005, so i bet it has a cooler, I might unblock the lowest grill inlet though, right now it is like 20 degrees, so I am not too worried about the heat.
Old 02-24-2009, 08:13 AM   #26 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
You could use his trick - get big mirrors and mount them on an angle so that the reflect the surface you are driving on. That's how George Lucas managed it.
Old 02-24-2009, 08:27 AM   #27 (permalink)
Does anyone actually know where you can buy chloroplast? Just curious, seems like a lot of people use it for mods, but I have never seen it in a store.
Old 02-24-2009, 09:24 AM   #28 (permalink)
Sign shops carry it. Also, plastic supply houses.
Old 02-24-2009, 09:42 AM   #29 (permalink)
Some people are lucky enough to buy it at hardware stores. Most of us who go for coroplast check the yellow pages under "advertising." Look for a company that advertises "weatherproof signs" or something - ask if they work with corrugated plastic.
Old 02-24-2009, 11:39 AM   #30 (permalink)
MPG...what?
sign shops, i picked upa 4x8x1/4" sheet of black coroplast for 50bucks & change...that reminds me, i need some more
you should be able to gain alot with a underbelly tray on the van, have you been undernieth it?? tons of places for air to catch, at least do the front, past the subframe brace...which will also give you a good spot to attach the tray to
-10 Yaris sedan
-96 Tercel
Newb - better MPGs out of a Dodge Neon? stevewww EcoModding Central 7 10-21-2011 08:50 AM
2008 Dodge Dakota AeroCap electricman Aerodynamics 52 10-08-2011 10:47 AM
'98 Dodge Caravan 3.0L - 26 mpg pulling a trailer & 24 mpg pulling another car :) MetroMPG General Efficiency Discussion 7 05-25-2009 12:27 PM
Dodge ZEO BEV sports car cfg83 General Efficiency Discussion 0 01-16-2008 10:55 PM
electric caravan 300 mile range oldschool Fossil Fuel Free 0 01-08-2008 06:29 PM
