Old 08-27-2010, 10:13 PM   #11 (permalink)
I'd suspect adding a sway bar to the heaviest end, or maybe both ends of the car would help your sway situation, possibly better than changing wheels and tires. If the bar(s) work well enough maybe you could save the expense of changing the wheels and tires. And if you can spare the ground clearance, lowering really does help add stability too.
Nice advice frank. A sway bar ets you add roll stiffness efficiently and also adjust the front to rear handling balance of the car.
Old 07-19-2013, 09:55 AM   #12 (permalink)
I've just bought myself a similar car. A 2006 4 spd automatic Daihatsu Charade. I got 50mpg (UK) on the 4 hour trip home in very hot weather. A/C on most of the time and tyres were a bit soft!
Owned by an old lady, it has done just 9000 miles. I'm hoping to get another one - 5 spd manual this time, as I am a driving instructor and teach both auto and manual.
I've been using two Perodua Kelisa's (Daihatsu Cuore) (auto and manual) for the past two years. Great little cars and very popular with my pupils. Not as good aerodynamically as the Charade, and hydraulic PS, so get 40mpg+ (UK) with both cars.
Old 09-09-2013, 06:56 PM   #13 (permalink)
Now I have a manual as well
I now have a 2006 Charade Manual - and got 65mpg bringing it home at motorway speeds and occasional aircon use.
The 2006 is supposed to have better handling compared to earlier models, but seems set up more for a comfortable ride than for ultimate handling.
I really like it!
Old 10-23-2013, 05:44 PM   #14 (permalink)
I can now say that the original tyres were 155/65 13 on 4in rims
I've found that using 4.5in rims from a Cuore/Kelisa fitted with 165/65/ 13 Michelin Energy E3B tyres does wonders for the handling - much less understeer - and helps with economy.
The change in diam is about 2.45% and makes the speedo about 2mpg nearer the true speed (as standard, the speedo overeads by 5mph)
Old 10-24-2013, 03:57 PM   #15 (permalink)
The PRC.
You can probably pinch wheels and tyres from the Aygo / 107 / C1. There are loads of them on the web as owners "upgrade" to wide alloys.
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Electric car heat! Liquid? bennelson Fossil Fuel Free 38 12-11-2009 10:59 AM
Aero suggestions for my car atomicradish Aerodynamics 17 07-27-2008 02:29 PM
