Old 07-13-2009, 03:50 PM   #1 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
No air conditioning?
A solution for those that have forgone a/c in their cars:
LINK!
Well... it should work... I think...
Old 07-13-2009, 04:32 PM   #2 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
When the A/C died in my Metro and the shop wanted several hundred dollars to replace the compressor, I considered something like that for months. (Well, except I was thinking about replacing the rear seatback with some plywood and mounting the A/C through that, then venting the heat out of the trunk.) My 10,000 BTU window unit only draws 450 watts (about 32 amps at 14V), so I figured I could wire it into the battery and not overpower the alternator.
Old 07-13-2009, 05:33 PM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Did that with a 5,000BTU unit in a Ford E350 Camper conversion. Worked nice.
Old 07-14-2009, 02:43 PM   #4 (permalink)
A spray bottle of water is lots cheaper - and probably works better, too :-)
Old 07-14-2009, 02:45 PM   #5 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
In San Bernardino, they call that "basting."
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Home made air conditioning article Fudog1138 General Efficiency Discussion 9 11-24-2008 08:13 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
