Go Back   EcoModder Forum > Classifieds > For Sale
Old 08-02-2009, 08:59 PM   #1 (permalink)
SaturnSl1 - '00 Saturn SL1
90 day: 40.21 mpg (US)
MyPickup - '96 Ford Ranger
CRX HF - '89 Honda CRX HF
90 day: 51.59 mpg (US)
1989 Honda CRX HF for Sale -- 55 mpg
My wife has been nagging me for a few months now to get rid of my CRX. We have three cars now and don't really have much use for this tiny one anymore. If you look at my fuel logs, I have gotten up to 55 mpg with this car. I think someone taking this on as a hobby could make some significant improvements to this number.
1989 CRX HF - High Fuel Efficiency model
1.5L SOCH with a manual transmission
1,830 pounds
199,000 miles on original engine
Engine runs well but (I think) has a small leak in the O-ring which causes it to burn a small amount of oil every few thousand miles
New starter put in last year
Valve clearance has been adjusted to factory specs
New clutch and much lighter flywheel -- The flywheel was just installed and I haen't had a chance to drive enough to see what difference it made, but it should be a good amount better.
New front brake shoes put in last year
Intake manifold ports were cleaned out last year along with the entire throttle body.
New exhaust from the catalytic converter back -- I have the muffler that it came with and the guy that sold it to me told me he paid over 600 for the tailpiece. If you want a car that sounds like a lawnmower, you can have that too.
New serpentine belt last year
No coolant leaks, and I think there is some sort of honda civic radiator that was put in before I owned the car.
It came with LED headlights. I think they might be called eurolights, or something like that.
Here are the problems that I know of:
I put in a heater control unit a while back. I didn't want to spend the 200 for a new CRX unit, so I spliced together one from a mid-90s accord. The slider to adjust for cool/hot is not connected. To get heat, you have to manually flip the valve inside the engine bay when winter starts.
The rear defrost did not work when I bought it so I put an aftermarket one on. It worked over the winter, but one of the sides is peeling off.
There is no key for the hatch (that is better than when I bought it when I found out there was no working key for the doors...)
The accelerator cable was not hooked up right after replacing the clutch. I am assuming this is an easy fix. At the moment, the odometer does not change and neither toes the speedometer.
The fuel guage works most of the time, but not all. I go by my trip odometer when filling up.
The hood release cable is busted. There is a cable in the car that you have to pull with pliers instead of being able to lift on the lever.
The stereo looks like crap. It was glued? in place. It works if though, if that's important to you.
I am trying to be as honest as I can, so that list of things that need work may seem long. Basically, this car is in good mechanical shape, has some typical rust that you would see on a 1989 car, and isn't too pretty on the inside.
I am asking $1,150 for it, which is way less than what I paid for it a year ago.
I live in Madison, Wisconsin and you would have to come to pick it up. PM me if you are interested.
ID:	3945   Click image for larger version
Old 08-02-2009, 09:01 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Good luck with the sale
Old 08-02-2009, 09:21 PM   #3 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
I want it but all I can do is trade for my neon
Old 08-02-2009, 09:23 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Sell the neon and buy it! Neon should be worth at least that much, eh?
Old 08-05-2009, 01:32 PM   #5 (permalink)
90 day: 34 mpg (US)
I honestly want a 1991 crx hf...
Old 08-12-2009, 08:49 AM   #6 (permalink)
Last chance to get it on ecomodder first. I will be posting this to the local craigslist sometime this week. It would be a shame to have some high school kid buy it and make it into a racer car.
As an added bonus (that I just forgot to put earlier) it does come with another muffler, which I was told cost over $800 to get the attachment that made it sound like a lawnmower. It also comes with a cold air intake if you would rather have that over the stock airbox.
If you can sell the muffler and tailpipe, the cost of this car will go down considerably.
Old 08-13-2009, 12:08 AM   #7 (permalink)
90 day: 34 mpg (US)
My offer is still up for the trade for my neon that's worth over 5k on kbb for your car worth maybe 1200 on kbb... You could have my car and turn around and try to sell it for more then your selling the crx >.<
Old 08-13-2009, 01:57 AM   #8 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
If some ricer paid $800 for a fart can, he got ripped off. He then lied to you. It probably cost about $80, including installation.
Selling it and the CAI will net about $100 on a good day, so "considerably" is not a good term to use there.
Consider that the average cat-back system for CRX's goes for under $300 anymore, brand new.
Frankly, I still maintain that $1200 is WAY too high for a CRX with 200,000 miles and a 62HP 8 valve FI engine, unless it's literally in MINT condition, with NO RUST at all. Even then, I'd have a hard time with that price, considering that there are clean ones going with less miles for ~$700.
Old 08-13-2009, 01:57 AM   #9 (permalink)
I don't mean to sound condescending there, but that's my .02 on the situation. I see/deal with Hondas all the time - they're just not worth that much.
The Following User Says Thank You to Christ For This Useful Post:
RandomFact314 (08-13-2009)
Old 08-13-2009, 03:19 AM   #10 (permalink)
90 day: 34 mpg (US)
So at least you understand why I think trading is a great deal for him
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
1986 Honda CRX - MPG Stats? SirKeats General Efficiency Discussion 2 06-10-2009 04:21 PM
1991 Honda CRX - New Here... Hi, Everyone! adam62882 Introductions 4 09-28-2008 10:35 PM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
