Old 02-27-2010, 03:52 PM   #1 (permalink)
Undecided - '96 Honda Civic HX
Last 3: 38.01 mpg (US)
Need new tires
Hi Guys, I just bought an Integra. It needs tires, and the tires that come with it are 195/55/15.
My question:
Buying 185/65/15 a good idea?
-Decrease wheel patch so less engine work
maybe enough to take advantage of the...
-Increase wheel diameter?
Other thoughts-Going to put headlight covers and lowering car.
Old 02-27-2010, 10:22 PM   #2 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
we need info on the car rpm @60, mostly city driving ? highway? auto-manuel? 4cyl? 6cyl?
Old 02-27-2010, 10:41 PM   #3 (permalink)
its an integra 98 auto
Old 02-27-2010, 11:10 PM   #4 (permalink)
ecomonkey
also study the rolling resistance of tires,, look at the tire rack prius llr tire compareison,, tires made as much as 4mpg difference (all the same size) im eyeballing the ecopias they were # 2 on that test and are good wet weather tires also.(florida is rainy) you still did not give enough info,, if you drive all highway, it might help your mpg going a little taller/if you drive alot of stop and go it could hurt your mpg,.
Old 02-27-2010, 11:14 PM   #5 (permalink)
Im sorry for being vague...mostly in-town suburban driving. I figured narrow is always better. And because of the narrow tire, the engine would need to do less work, so could handle running less rpm with a taller tire.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Bridgestone Tires and LRR gone-ot EcoModding Central 30 05-04-2010 12:31 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 02:05 PM
Crapped. 2 tires have bubbles. XyKo EcoModding Central 37 09-04-2008 04:55 PM
