Old 02-11-2013, 09:20 PM   #1 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Need an oil for my gearbox.
My 1994 Geo prizm (Toyota corolla) has a 5 speed manual. It shifts like garbage when cold, I am running this (75W-90 GL5 Valvoline.com > Products > Grease Gear Oil > Gear Oil > SynPowerŽ Full Synthetic Gear Oil )in it. By garbage, I mean that it is almost impossible to avoid crunching in the lower gears when it is cold.
What gear oil should I use?
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 02-11-2013, 09:24 PM   #2 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Pennzoil syncromesh is one that a lot of people use in manuals. I'd do a little research before you make a decision. Could also be possible that your syncros are shot, but hopefully a better fluid will clear things up for you.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 02-12-2013, 12:31 PM   #3 (permalink)
KLR650 - '10 Kawasaki KLR650
6.4 - '19 Ram 3500
All Black - '19 Kawasaki Vulcan S
Do not use a GL5 oil... Go out and buy some Redline MTL or MT-90 GL4 manual transmission fluid. You will notice the difference immediately.
I once swapped in a GL5 oil in my old '09 Vibe. It was instantly hard to shift and after the first day, became impossible the shift into 3rd without double clutching. Different transmission, yatta yatta... but the premise is the same, you can read up on the poor performance of gl5 fluids in small cars on many forums.
Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MTL 70W80 GL-4 Gear Oil
You can find this product stocked on the shelf at most hotrodder/aftermarket performance shops. Napa ect won't stock it.
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
Old 02-12-2013, 06:41 PM   #4 (permalink)
Do you have an owner's manual? If so, it should tell you what kind of oil to use in the gearbox. Some newer manual transmissions actually use ATF, so a regular gear oil would be far too thick for them.
-soD
Old 02-12-2013, 06:51 PM   #5 (permalink)
The manual for the geo prizm says that I should use SAE 75w-90 GL-4 (GM part number 12346074 Castrol Syntorq GL-4 or equivalent) or SAE 75W-90 GL-5 gear lubricant.
Old 02-12-2013, 07:56 PM   #6 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
I love the Redline MTL.
I'm not coasting, I'm shifting slowly.
Old 02-12-2013, 10:52 PM   #7 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
+1 for Redline MTL. Helped my car shift better in cold conditions.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 02-14-2013, 10:37 PM   #8 (permalink)
If I have to buy a gear oil at a B&M, what would be recommended?
Old 02-15-2013, 12:41 AM   #9 (permalink)
6.4 - '19 Ram 3500
Buy Redline MTL or MT-90 GL4. Nothing else. Any GL5 product you put in your transmission will do the exact same thing it's doing now so don't cheap out. Find a store that sells Redline or buy it online and have it shipped.
No compromise!
Old 02-15-2013, 08:32 AM   #10 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
If the syncros are brass your sycros are quickly being destroyed by the GL5 oil.
Here is an article that helps explain why you should not use a GL5 oil in a sycromesh transmission.
http://www.widman.biz/uploads/Transaxle_oil.pdf
Project Avalon: E bike build
