Old 04-04-2025, 04:32 AM   #31 (permalink)
I've a better memory for pictures than text. Sorry.
Originally Posted by Andyman
As the pipe size increases, the flow must slow down to fill that larger volume, so when the exhaust 'gets out' it's no longer trying to 'spray' ambient air out of the way.
I posited that 'disappat[ing] the exhaust without slowing it' might achieve that. The only analog I can recall is a trumpet mute.
https://trumpetheroes.com/wp-content...-1024x683.jpeg
Now I've moved on to wonder about cymatics.
edit: on the Beetle I found the model but not the .MTL file so it lost the colors and textures. I've cut away the back window and deck lid and mocked up the Coanda nozzle, but now it seems I need to master Curve to Mesh operations to move forward.
The older I get, the better I was -- John Fogerty on Joe Rogan
Old 04-04-2025, 01:44 PM   #32 (permalink)
amateur mech. engineer
Sporty Accord - '88 Honda Accord LX-i
90 day: 23.25 mpg (US)
Dad's Camry - '01 Toyota Camry CE
90 day: 22.81 mpg (US)
That quote was from Logic, not me. He wrote it for me.
Old 04-04-2025, 04:44 PM   #33 (permalink)
I retract any and all attribution. That's easier than going back over everything from Permalink #25 and onward.
Could one combine cymatics and the Tesla one-way valve? Vary the size and spacing of the convolutions to address a wide[r] range of frequency?
Old 04-07-2025, 03:22 PM   #34 (permalink)
...Could one combine cymatics and the Tesla one-way valve? Vary the size and spacing of the convolutions to address a wide[r] range of frequency?
...Could one combine Helmholtz Resonance and the Tesla one-way valve?...
freebeard (04-07-2025)
Old 10-29-2025, 12:13 AM   #35 (permalink)
Old 10-29-2025, 02:11 AM   #36 (permalink)
Oversteer much?
They could've run the big motor's exhaust forward and put the turbo closer to the little engine's
header to reduce back pressure.
Or just use an electric turbo?
Old 10-29-2025, 05:27 AM   #37 (permalink)
Oversteer much?
These mad Russians do all shorts of crazy sh!t just to see what happens.
In this case the video answers Ecky, the OP's original question very well IMHO?
Ecky (11-23-2025)
Old 02-02-2026, 11:57 PM   #38 (permalink)
Insight (Winter) - '21 Honda Insight EX
90 day: 47.43 mpg (US)
It does! honestly i watch their videos for ideas for modding my car
My last Ecotec project...
Old 02-04-2026, 10:35 AM   #39 (permalink)
But do you know whether the modification actually works as designed? If they fudge the data, the build and the results how do you know it actually works?
Old 02-05-2026, 01:04 AM   #40 (permalink)
NO ONE is going to fit an equally sized engine to vacuum exhaust out of the 1st engine.
IF
Except for You/tube content where you will get the same number of clicks whether it works or not:
No-one is going to do it
THEN
What's to be gained from fudging the numbers..?
What is free is the low pressure behind a moving car.
https://www.wrcwings.tech/2022/03/22...rc-rally1-car/
https://www.wrcwings.tech/2018/05/04...fusers-in-wrc/
https://www.wrcwings.tech/2018/10/15...rear-diffuser/
