Old 11-16-2012, 12:09 AM   #1 (permalink)
Deceptive - '98 Dodge Neon R/T
90 day: 44.38 mpg (US)
Neon airdam testing
Since this became such a heated topic on the neons forum, I decided to do some coast down tests between the stock airdam, and no airdam. The test was an A-B-B-A test, where the A tests were without airdam, and the B tests were with. For each test, I got two coast down times, one in each direction. Ambient temperature stayed at 64 degrees for the duration of the test, humidity at 39%. 3mph wind NW, test direction was East then West. Coast down speed was timed from 65mph to 50mph on an empty road. Tests were not done while cars were passing.
A 1- 22.3 sec 2- 20.6 sec
B 1- 21.1 sec 2- 19.9 sec
B 1- 21.4 sec 2- 20.1 sec
A 1- 22.7 sec 2- 21.0 sec
Average them together, and it shows a 5% increase in drag with the stock airdam on the car, vs without it.
This is the airdam in question. It is a stock piece. The issue is that without this piece, a stock neon would overheat. So the car needs a ducted radiator.
The Following 2 Users Say Thank You to TOOSTUBBORN2FAIL For This Useful Post:
AndrzejM (11-16-2012), JRMichler (11-16-2012)
Old 11-16-2012, 06:06 AM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Interesting numbers... It shows that air dam is not always helping. I've planned to attach one to my Berta, but now I know that I have to use cardboard model first and take it for a spin to do A-B-A tests.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 11-16-2012, 02:24 PM   #3 (permalink)
maczo's Avatar
scrapcento - '99 fiat seicento
90 day: 30.15 mpg (US)
fokus - '08 Ford Focus
90 day: 31.15 mpg (US)
tdm - '95 Yamaha TDM 850
90 day: 27.72 mpg (US)
vespa - '04 Piaggio Vespa ET4
90 day: 57.6 mpg (US)
PCX - '10 Honda PCX
90 day: 78.33 mpg (US)
avensis - '13 Toyota Avensis
90 day: 39.77 mpg (US)
Judging by the photo, the airdam is pushing the air into the engine compartment, not over the car (as opposed to the recommended location, extending from the bumper). Given that, the results shouldn't be surprising, right?
The Scrapcento thread
The Following User Says Thank You to maczo For This Useful Post:
GRU (11-16-2012)
Old 11-16-2012, 03:43 PM   #4 (permalink)
This was exactly my argument on the neon forum. Theres a guy there that built an engine undertray, and this guy that sells "airdams" like the one above, but that extend an inch lower, and extend several inches wider on both sides, is trying to convince people that its more aerodynamic. Hes also trying to say that a duct for the radiator wont work unless its inlet is inches from the ground.
Aside from that, after seeing a few new neon people on this forum, I figured it would be a good test to run.
Old 11-18-2012, 12:08 PM   #5 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I guess the front end looks like this?
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 11-18-2012, 01:24 PM   #6 (permalink)
Yep, that's the "monster" airdam that the guy sells. Easily 3" wider on each side, and extends an inch lower.
My car currently has the lower airdam blocked so only the two inner most openings were open, and the fogs were covered. Unfortunately, the upper crossbar piece for the upper grill is removed, as I'm in the middle of working on a new bumper for the car that covers it completely. That will get finished as soon as the radiator duct is done. Problem is, epoxy resin doesn't do too well in wet weather.
Old 11-21-2012, 07:55 PM   #7 (permalink)
Wow, said thread on the neon forum went down the toilet. Apparently, coast down tests are worthless, wind tunnels are the only way to measure drag, and the huge airdam might actually help mileage by slowing the car down to a lower speed. Oh, and dodge wouldn't add it stock if it wasn't the best way to do things.
