Old 01-27-2010, 06:35 PM   #1 (permalink)
low&slow's Avatar
l&s' Jag - '00 Jaguar S-Type SE
90 day: 25.86 mpg (US)
l&s' Vision - '82 Yamaha Vision XZ550RJ
90 day: 59.92 mpg (US)
L&S' Greenaero Ninja 250 - '99 Kawasaki Ninja EX250F Ninja 250R
90 day: 97.24 mpg (US)
SilverAero Ninja 250 - '04 Kawasaki EX250 Ninja
90 day: 88.24 mpg (US)
NICE-on Coasting; AT Hypermiling
Hi, I attended my first mini hypermiling clinic led by SentraSE-R ( Darrell) and got to see an elite hypermiler in action. It was great! I also got to see pulse and glide with an AT performed by Kris, a fellow hypermiler. After seeing it done safely and effectively, I decided to go ahead and add this to my hypermiling efforts. I tried it out on the way home from the meet and have been using it when I get the opportunity to do so safely. No noises or other distress, just smooth engagement when shifting back into Drive!
I just refilled my gastank so I should be able to check my results in another 400 miles or so. I'll report on the results. My last few tanks have been in the mid 27mpg range. I drive a 2000 Jaguar S-Type ( 3L V6, 5sp AT ) that has an EPA rating of 19.
Kudos and thanks to Darrell and Kris for their assistance.
L&S
Old 01-30-2010, 09:00 PM   #2 (permalink)
Driving the TurboWeasel
Glad to hear it's working for you! Check about needing to rev-match your AT or whether you don't need to.
2012 Chevrolet Cruze Eco 6MT
The Following User Says Thank You to 99LeCouch For This Useful Post:
low&slow (01-30-2010)
Old 01-30-2010, 09:34 PM   #3 (permalink)
low&slow's Avatar
Hi,
What seems to work best for my Jag is to just shift back into drive, wait a second for engfagement and then start the pulse. I'm hoping to meet with Darrell again so we can use his scangauage to determine the most efficient acceleration . So far I'm not seeing a large difference but I've been forced to do a lot more short trips and city traffic than usual. Ir does make it more fun so I'll keep doing it as long as there is no downside.
Regards, L&S
Old 02-18-2010, 10:29 PM   #4 (permalink)
Ah now I understand. I seem to like that IR too but always be careful with it... You know
Hypermiling techniques that are invalid (potential mechanical wear/cost) Ptero Hypermiling / EcoDriver's Ed 68 08-24-2009 01:02 AM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 01:28 PM
EMAIL friends results to PROVE hypermiling works mush3gan Hypermiling / EcoDriver's Ed 8 07-23-2008 03:24 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
